Many questions
Old Aug 18, 2003 | 02:00 AM
mrronatron's Avatar
Many questions
Well i finaly got my 91 z28 305 5-speed on the road and i have a few questions
One. My car while just driving around normally is usually around 180* which is normal, but there are times when it reads 220 or higher but seems to be running fine....is that normal?
also the hotter the engine seems to get the harder it is to shift the tranny, it will get stuck in gears and be hard to get into them...i have a hurst short shifter...i know that that tends to stiffen up the shifts... should i maybe change the gear oil? or is it a problem with the tranny...after about an hour of driving i start to get back pains its so hard to shift....also putting the tranny into reverse is very rough....a clutch adjustment will fix that right?
any info you have on both of these subjects is appreciated ...thanks in advance...ron
Old Aug 18, 2003 | 02:46 AM
aklim's Avatar
I have an A4 so I don't know about the second question. Anyway, under what circumcisions does it go to 220? In stop and go traffic in the summer with the AC on max, mine does too. Is the coolant fresh and in the right proportion? Is the gauge reading right and is the thermostat working like it should?
Old Aug 18, 2003 | 12:31 PM
mrronatron's Avatar
i was kinda figuring that something was off because the engine runs fine still
Old Aug 18, 2003 | 03:35 PM
Black6SpdTA's Avatar
About putting the tranny into reverse:
You say it's very rough. Do you mean it grinds? If so just shift into 5th first then slide her back into reverse. No more grinding
-Rippin
Old Aug 19, 2003 | 01:40 AM
mrronatron's Avatar
ill try that out, but what about not being able to get it into first at times? or missing gears really badly....im a good driver too, ive driven many of cars and never had a problem missing gears, but i mean it hurts my back i have to push so hard to get it into gears
Old Aug 19, 2003 | 12:58 PM
TheGreatJ's Avatar
Sounds like the clutch is dragging. You may have air in the clutch hydros...try bleeding them and see if it does any good.
Old Aug 20, 2003 | 12:36 AM
mrronatron's Avatar
if you could maybe tell me how to do that, im 18 years old...not really much mechanical experience
Old Aug 20, 2003 | 07:27 AM
DrDUKE's Avatar
a $20 haynes manual will show you how, and teach you a lot of other stuff too. IM not trying to be an ***, it would be better exlplained in there is all.
Old Aug 20, 2003 | 12:53 PM
TheGreatJ's Avatar
Haynes is worthless. If you're gonna buy a manual get a real one from Helms. It costs almost $100 but it's worth every penny. You'll never have to ask a service/maintenance question again.
Bleeding the clutch takes 2 people. Jack up the front of the car and crawl under the driver's side. Locate the slave cylinder, and find the small hex-drive bleeder plug (on top next to the line.) Have a helper work the clutch 3 or 4 times and hold it down. Open the bleeder valve and let fluid (and hopefully air bubbles) flow out until it stops. Close the valve, then have the helper pump and hold again, and repeat the bleeding process. 3 times should be more than plenty...make sure the reservoir doesn't empty out or you'll have to start all over again.
Old Aug 20, 2003 | 10:54 PM
mrronatron's Avatar
i found everything i needed to do it
i just didnt have anyone around to help me
tomorrow sounds good
Old Aug 20, 2003 | 11:52 PM
DrDUKE's Avatar
Ive done it solo before, pump it a few times and then lay a brick on it. Bleed it. Rinse and Repeat anywhoooo
Old Aug 22, 2003 | 08:00 PM
mrronatron's Avatar
big problem, or atleast i felt like saying that...the line that runs into the slave cylinder has a hole in it somehow....how easily replaced is this?
Old Aug 23, 2003 | 10:58 AM
TheGreatJ's Avatar
It's not too rough to replace. You have to pull out both the slave cyl and the master cyl, but once you get them out the line is just held in with a roll pin on each end. Tap the pins out with a punch and the line will pull right out.
Finding a line might be a problem though. I dunno if you can get it seperately or if it only comes with the whole assembly.
Old Aug 23, 2003 | 03:52 PM
mrronatron's Avatar
i checked the local parts shop where i usually get everything and they cant get it, so im gonna try gm, but i think my best bet will be a junkyard...if anyone knows anywhere else i woudl appreciate...thanks
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
