Low RPM Surge...
Low RPM Surge...
My 1991 RS will usually idle at about 700 rpm's. In the past few days I have felt some slight surging while waiting for the green light. I have been trying to catch the exact rpm's that it surges too but I haven't been able to catch it in time yet. My estimate would be that the rpm's are surging from 700 up to 1000 or 1100.
What steps do I need to take to correct this problem?
TIA!
TIA!
Re: Low RPM Surge...
my guess is ...............IAC assembly or TB, use brake cleaner and clean TB...., can also be a bad sensor...........
you might need to put it on a computer for about 39 - 55 dollars for diag ....at a garage with scanner.... they will also flush out the iac.... if thats the problem..
good luck i got the same problem with my 85 iroc TPI and i am at this point with the car. if a sensor is reading wrong and the computer is telling the cold start injector to fire...etc....there are alot of derivatives to this problem.
resetting TPS is also possible.
i am taking my car to a garage this week for diag, to many variables for me.
solution for me:
1. so i will start with a computer diag, get my iac counts with there scanner adjust tb if reading is wrong. get feedback on my iac and pintle which i got my eye on ....i am also concerned the problem could be a bad sensor messing up my computer...
solution for me:
Noenav
Apr 30, 2015 01:06 PM
