Low Compression Issues
Old May 8, 2008 | 11:50 AM
DrZ28's Avatar
What could be the cause of low compression in my engine? I have a 1983 Camaro z28. Just pulled it out of storage. Its been there for 4 years straight. Last time it ran, it had low compression
Old May 9, 2008 | 12:25 AM
NaturallyAspirated's Avatar
More than likely the rings are shot. You could be losing Compression through them if they aren't good anymore. Or could even be head gaskets, if they are broken and tore up then could be the same deal with that as well.
Old May 9, 2008 | 10:39 PM
go2fast's Avatar
Check the compression and then squirt some oil into the cylinder and check it again. If the compression goes up, it's probably rings. If it's unaffected, it's probably valves.
Old May 12, 2008 | 11:16 AM
DrZ28's Avatar
There car's been sitting for 4 years but it only has 56320 miles on it. The rings could go bad that quick?
Old May 12, 2008 | 11:25 AM
Tex95Z's Avatar
I think you first need to find out about that screw! then get your car ready to run, then check your compression.
https://www.camaroz28.com/forums/sho...d.php?t=600988
Magenta_Hearts
Mar 25, 2015 10:24 AM
pimpss96
Feb 12, 2015 01:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
