New To Muscle Cars. Need Engine Help!
Old Apr 27, 2008 | 11:31 AM
DrZ28's Avatar
Unhappy New To Muscle Cars. Need Engine Help!
Ok so I just purchased a 1983 chevy camaro z28 for $50 from one of my mom's co-worker. He bought it from an old guy years ago. It has 56320 original miles on it, automatic, very clean. About 2 years ago, he had a neighbor working on the engine, trying to install something aftermarket. He said he thinks the guy dropped a screw where one of the pistons are but he doesn't know for sure where he dropped it. He said he started it up once since then and never took the car out of the garage since then. I don't have any idea where to start on this car because I've never even touched a muscle car before so I need some help from some experienced people here. All I know is that it's the original LG4 305ci V8. Other than that, I'm clueless. Can yaw help me out?
Old Apr 27, 2008 | 12:18 PM
rik89gta's Avatar
Welcome to the boards! You oughtta post pics of Your new ride. But what exactly do You need help with? Somebody said that someone dropped a screw near a piston...... ok well does it run? Or are You just afraid to fire up the motor cuz You fear theres a screw loose in there?
Old Apr 27, 2008 | 04:52 PM
DrZ28's Avatar
he said he started up the car once and he heard it so he never ran it again. its been in the garage for 2 years now. i dont know whether to fix the engine or replace it. He doesnt know exactly where the guy dropped the screw
Old Apr 27, 2008 | 05:32 PM
lordmetalz28's Avatar
well sounds like your scared to run it,, in your case your gonna have to take it apart to either check for that screw or to REMOVE IT,, but if you plan on replacing that motor anyway,, just start it and see what happens,, if you bought the car with 56k original miles for 50 bucks,, HE KNOWS that somethings really screwed up thats insane,, i cant even buy junk camaros for 50 bucks
Old Apr 27, 2008 | 05:40 PM
DrZ28's Avatar
well i dont know if its cheaper to replace the engine or fix the engine so that's why Ive came to you guys for help. This is my first muscle. The guy that had the car doesnt know anything about cars. He initially want 1000 for the car but my mom did some work for him wit taxes and some other stuff and he pretty much just want the car gone so he can park his new car in the garage.
Old Apr 27, 2008 | 07:46 PM
just run it,, you dont know a damn thing until u run it,, unless he had the heads off i dont thing its possible to get something on the piston, unless he shoved it down the spark plug hole,, charge the battery ,,check the fluids run her for a while,, u will never know unless u run her,, taking the heads off and looking for a mystirious screw sounds odd and like a waste of time, if its real bad on start up then u know your options rebuild or replace that motor
Old Apr 27, 2008 | 07:54 PM
DrZ28's Avatar
so should i take off the head first and see if i can see the screw sitting up top? or just check the fluids and then start it right up. should i change the gas since its been sitting for 2 years?
Old Apr 27, 2008 | 09:15 PM
id just run it for 50 bucks you cant go wrong specially if youve already factored in a new engine but thats my opinion
Old Apr 27, 2008 | 09:21 PM
DrZ28's Avatar
alright. well ill try and start it and see what happens
Old Apr 27, 2008 | 09:42 PM
Tex95Z's Avatar
Just to say I was a little proactive I would at least take the manifold off. He could have dropped the screw into the carb/Throttlebody, but thats just my opinion. I would rather remove parts as far down as the heads rather than spend all the extra money on a new/rebuilt engine.
Old Apr 27, 2008 | 09:45 PM
DrZ28's Avatar
well i would do that, but like i said, im completely clueless on these engines. The only engine ive ever worked on is a 7mgte (turbo 1987 toyota supra) so this is new to me
Old Apr 27, 2008 | 10:09 PM
Tex95Z's Avatar
http://www.thirdgen.org is your friend!
check out the classic tech section on this site too. you will basically just need to take some pictures, label everything you take off/ disconnect, take your time, and ask lots of questions on here (this is where the pictures will really help) also shoot me a pm if you have any ????
Old Apr 27, 2008 | 10:11 PM
DrZ28's Avatar
alright. will do. thanks for the info.
Old Apr 28, 2008 | 11:24 AM
Rice Killer87's Avatar
If you run it w/ the piece of 'whatever' down in the motor,hope you plan on a rebuild or a new engine.
It needs to be taken apart and pull the heads off to get out whatever got dropped down in there.
Yes on draining the gas and putting new in.
Old Apr 28, 2008 | 01:05 PM
DrZ28's Avatar
how do i get the gas out?
