SLP runners
Old May 6, 2008 | 06:04 PM
mpilarZ281992's Avatar
Question SLP runners
As the name implies, I got a 92 Z 5.7. The engine has not been internally mod; only the exhaust. I am interested on modifying the air induction. I was wondering if the SLP runners are just a simple bolt on or do I need to anticipate any other adjustments. Also I was going to port the plenum at the same time, but keep my 48mm throttle body. Should this be a reasonable option and what realistic hp gains could I have from this???
Old May 8, 2008 | 07:48 AM
teke184's Avatar
should see some gains...especially from the ported plenum
while you have it out...i would port the TB openings
Old May 9, 2008 | 01:33 PM
1987IROC350's Avatar
The runners alone are worth 10-12hp I think. Not sure about porting.
But if your not going to go with a bigger tb you should get the tb airfoil. This add claims the airfoil adds another 5.8hp
http://www.holley.com/120-140.asp
EDIT: they claim 20 extra hp w/SLP http://www.lmperformance.com/1748/7.html
Old May 11, 2008 | 01:52 PM
AutoRoc's Avatar
I ported the inside of the plenum to get rid of those walls on the bottom. Siammesed the holes on the side so they look like a number 8 without the middle line. Matched the runners and all opening to the gasket size, possible a little bigger and made the gasket bigger also. Doing this and shifting 1-2 at 5500 instead of 5000 netted me my biggest gains. I think I went from 15.20's to 14.40's 3mph increase roughly. It's probably 20+HP.
Old May 12, 2008 | 02:30 PM
Thanks for the replies. I expected a modest gain around 15-20 total. I think im going also for an adjustable fuel regulator as well. After this its all internal in the future.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
