loss of fuel pressure
Old Aug 15, 2005 | 02:15 AM
kandied91z's Avatar
driving down the road, no signs of troubles and the car shuts off with zero fuel pressure. everything electrical still works. the obvious signs are there but i'd like to get some opinions on things to check.
the pump is a walbro 255 340 racetronix kit which is 2 years ( 3,400 miles) old.
running 60 psi though if it matters..
Old Aug 17, 2005 | 02:21 AM
Runin2Nite's Avatar
Re: loss of fuel pressure
does it start rite up after it dies??? maybe a short?? how do you know its loss of fuel?
Old Aug 17, 2005 | 01:38 PM
kandied91z's Avatar
i have an electric fuel pressure guage in the car.
well after going through all the fuses and wiring, even checking the relay on a dvm it looked a little toasted so i bought a new fuel pump relay for $12 and plugged it in. car fired right up. only after jumping the main lead for the pump and realizing that the pump was good i figured there was nothing left. rather rediculous but happy it all works.
Old Aug 17, 2005 | 11:37 PM
V8Rumble's Avatar
Wow - are your injectors OK with running 60 psi?
I seem to recall that the stock range is somewhere in the neighborhood of 42 - 50 psi or so... (Although it's been a few months since I've worked on my car, so I could be mis-remembering..)
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
charchri4
Apr 14, 2015 06:40 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
