looking for a place to mount a msd box
Old Aug 14, 2005 | 11:04 PM
Runin2Nite's Avatar
i've been pushing the box around under the hood all day looking for a good spot to mount it with no luck. i removed most of my a/c stuff, i would like to remove the a/c box on the firewall but i heard i need to box off the hole or somthing. any tips on where i can put it or how to block off the a/c box so i can mount it there????
Old Aug 14, 2005 | 11:19 PM
LoudmouthSS's Avatar
Re: looking for a place to mount a msd box
im having the same problem...
i think my box is even smaller then yours...and i still cant find jack **** to mount it too
Old Aug 15, 2005 | 11:18 AM
Runin2Nite's Avatar
how bout the heater box.... can i cut that thing up some how and seal it up so my blower motor still works???
Old Aug 15, 2005 | 05:48 PM
Solidous_Snake's Avatar
What about you do away with the windshiield fluid tank?
Old Aug 15, 2005 | 08:51 PM
anthony714's Avatar
hoss its your car ,mount where ever,but why do you have to cut up heater box,it 4 small screw holes,fyi if you mount and metal especially firewall use some rubber grouments underneath to avoid annoying hum/rattle
Old Aug 15, 2005 | 09:16 PM
thirteen20z28's Avatar
I was lucky enough to find a non-a/c heater box and bolt it on....hello spark plugs and header bolts! i ditched my windshield washer fluid reservoir and mounted the msd box there.
Old Aug 16, 2005 | 02:23 AM
Runin2Nite's Avatar
is it possable to get a smaller reservoir, cuz my 88 has a monsterous 1
Old Aug 16, 2005 | 02:24 AM
Runin2Nite's Avatar
any comments on how it might work if i stach it inside the car under the glove box area???
Old Aug 16, 2005 | 09:00 AM
diehardgm's Avatar
I saw one that a guy made a bracket to mount it right above his battery. Looked pretty good.
Old Aug 16, 2005 | 12:40 PM
Z28SORR's Avatar
On my 84 I mounted it inside under the dash. It's protected from the elements, and the heat & vibration of the motor. Definately use the shock mounts.
Old Aug 16, 2005 | 09:28 PM
anthony714's Avatar
if you want a smaller resoviour you can get on from liek an older ford,its just a bag,nice and compact,besides how much washer fluid u use?
Old Aug 17, 2005 | 02:19 AM
Runin2Nite's Avatar
hello mad heat and possable damage
Old Aug 17, 2005 | 10:01 AM
i'm thinking that you misread....i mentioned the non-a/c heater box just because it came up in the post, but that is NOT where i mounted the msd box....i mounted it over on the inner fender where the washer fluid reservoir used to be, perfectly safe from extreme heat.
Old Aug 17, 2005 | 11:48 PM
Wishmaster's Avatar
mount it inside the car..thats where I have my digi 6 mounted. go to thirdgen and do a search and you cna see a picture of it.
Old Aug 18, 2005 | 12:30 AM
Runin2Nite's Avatar
nice... is it safe to drill holes through the firewall like rite below the heaterbox???
