L98 Vette heads
Old Feb 22, 2004 | 10:57 PM
f-bodybuilder's Avatar
L98 Vette heads
How much lift can aluminum L98 vette heads take?
Old Feb 23, 2004 | 06:20 PM
transxtreme's Avatar
.500
Old Feb 23, 2004 | 09:16 PM
sousa's Avatar
.500
I ran the TPIS ZZ-9 cam with a 1.6 rocker on the intakes with my 'vette heads and the lift was .520/.520 with no clearance issues.
Old Feb 23, 2004 | 09:59 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Its not just clearance issues you have to worry about, but what the springs are made to handle. If you put in a cam with too much lift for the springs, a spring could break. Which would be bad.
You might get away with it, but you might now.
I would think they are made to handle about .460-.500 safely.
Old Feb 24, 2004 | 01:34 PM
aklim's Avatar
Just have the heads reworked to handle the lift. My heads could handle the lift but I decided to go for a better spring package.
Old Feb 24, 2004 | 02:20 PM
Z28SORR's Avatar
I've used the LT4 Hot Cam Kit which gives .525" of lift. This was with over size valves on a ZZ4 short block, with no clearence issues.
Old Feb 24, 2004 | 03:45 PM
aklim's Avatar
But this is an L98 not an LT4 so I don't think it is the same thing.
Old Feb 24, 2004 | 03:49 PM
sousa's Avatar
You are right. I also used a set of Comp Cams conical shaped valve springs to cope with the extra lift. No need to machine the spring perches.
Old Feb 24, 2004 | 04:00 PM
aklim's Avatar
Well, if you go that way, I suppose you would be fine to go as high as the spring will allow and the piston doesn't hit the valve.
Old Feb 24, 2004 | 04:48 PM
trackbird's Avatar
K-Motion makes the K700 or K750 springs that fit that head and give over 300 lbs of open pressure and about 135 lbs on seat. I used those with a roller on those heads. They fit the stock spring pockets. A good choice if you need more spring pressure on those heads.
Old Feb 25, 2004 | 12:23 PM
Z28SORR's Avatar
This was on an L98 with the aluminum heads. The LT4 Hot Cam Kit can be use on earlier roller cam. SB's.
Sorry i didn't make that clear.
I used stock L98 aluminum heads, had them machined for over sized valves, the LT4 springs, pocket ported and port matched to the intake.
As I said there were no clearence issues with the rated .525 lift. So I see no reason that the L98 could not support higher lift cams.
P.S. The engine produced 401rwhp.
QuickSilver02
Apr 7, 2015 11:12 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
smokin25th
Jan 1, 2015 09:06 AM
