Which Knock Sensor to Use
Old Jun 29, 2006 | 02:04 PM
ibmtech's Avatar
My car was originally a 1987 IROC-Z with a 305 T.P.I. I have since converted in more than 1 way. I have changed the engine to a 355cid with Miniram and changed the ECM from a 165 to a 730 and soon will be switching to a 749 ecm. I removed the MAF and installed MAP. Changed to a 350 knock sensor. I am getting about 6 knock counts on startup and knock is cycling excessive 250 and starting over again once I get over 1500 rpm using datamaster and my Snap-on MT2500. I have bypassed the ESC because the 730 controls timing in the ECM.
I have heard that there a differences in the knock sensors.
305 ~vs~ 350
MAF ~vs~ S/D
AND TPI ~vs~ TBI
I am almost 100% posivitve that the knock sensor is bad that I have now. Does anyone have a good number of one to buy.
Old Jun 29, 2006 | 08:13 PM
Wishmaster's Avatar
Re: Which Knock Sensor to Use
HMM?
I wonder if im going to need the same knock sensor as your looking for ...for my 383
Old Jun 29, 2006 | 08:31 PM
89Vert's Avatar
you need a 350 knock sensor from an SD car,
also use a brass NPT elbow to space the sensor off the block if you find its alittle on the sensative side,
I disable the knock sensor in my car and I've done it for others
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
