Intermit. starting problems
Ok, here is the deal. Sometimes ill go to start my camaro and it will just "click" it will do this a couple of times or just once and then start right up. Ive replaced the Positive bat cable cause it looked worn, I put in a new starter, Alt, and battery and checked all the grounds. Im not sure if the grounds are where GM put them. The battery is grounded to the fender on the passenger side on the side by the battery, and the firewall is grounded to the intake manifold. Both ground wires are new with new connections. Some days it will start up everytime, somedays it will just hesitate and turn and somedays it will just click a few times everytime you turn the key then it will fire right up. Im at a loss. do you think it could be my ignition module or anyother part of the ignition, either key or whatnot? Or maybe the ECM is wanting to go bad? Im at a loss any help would be great thanks.
Re: Intermit. starting problems
I just put a new starter on it. And it was doing the same thing with the old starter. I put on a new positive battery cable also. Since the key has that chip in it, could it be going bad? Maybe a bad connection?
) and havent had a problem since.jsut get a replacement chances are the silonoid is bad.
i say this because the symptooms you are describing fit that diagnosis to a T.
get a new starter, but this time you should use one of those heat blankets that wraps around them and is secured w/ either a strap or velcro. Summit store
I used to have this happen to me all the time, especially if i would have the car running for a while go, in somewhere quick and come back out to start the car and all it would do it click. My solution for this for a while was just to carry a pry bar around and when it would happen just whack the starter a couple of times and then give it a shot.
Usually what happens is the solenoid heats up, the plunger will only go about 3/4 of the way out and then get stuck. Hitting the starter will jarr the plunger loose so it can go back into its housing.
after using the heat shield w/ a new starter i never had the problem again.
Well, I just got off the phone with the shop. They said they benched tested the starter they put on and it was bad. Something bout a magneto...So, I go pick it up tonight and we will see. Thanks for all your help.
Oncomingstorm22
Jan 22, 2015 07:15 PM
