idleing high?
Old Aug 27, 2007 | 03:44 PM
98blckz28's Avatar
idleing high?
when i start my car up it turns over and then it will idle for a while at about 1500-2000 rpm for an odd amount of time. sometime after i drive it for a while it will go down to about 750.. any ideas on why it is doing this and why it is doing it for so long? could it be carb issues?
Old Aug 27, 2007 | 04:14 PM
Z28Horn's Avatar
Specs on the car please... Motor, trans, carb type. I would check for vacuum leaks.
Old Aug 27, 2007 | 04:22 PM
98blckz28's Avatar
its an 86 iroc with the 305. im assuming it is the 650 carb. i took off the stock breather and there is an open vacuum line. advance didnt have a big enough plug to put in when i went down there.
Old Aug 27, 2007 | 04:39 PM
98blckz28's Avatar
i also just went out there and noticed there is oil sitting right below the carb. any ideas on what that is from?
Old Aug 28, 2007 | 04:49 PM
Rice Killer87's Avatar
How many miles are on it?
Where is the oil located,on top of the intake or inside it?
Might just need the carb gone through and cleaned out.
Old Aug 28, 2007 | 07:07 PM
98blckz28's Avatar
40 on the motor.. a buddy said it was either blown valve cover gaskets... cracked intake or a piston ring. i am going to change the valve cover gaskets this weekend and see if that solves the problem hopefully
Old Aug 29, 2007 | 09:57 AM
Could be any,maybe the V/C's are a little loose.
An open vacuum line will cause a high idle,get that fixed.
Old Aug 29, 2007 | 04:00 PM
1racerdude's Avatar
If it has an automatic choke that will do it. It idles fast when cold and slows it down as it warms up.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
ChrisFrez
Mar 1, 2015 01:33 PM
IRABuss
Sep 7, 2011 09:08 PM
