Harmonic balancer install
Old Dec 19, 2006 | 08:08 AM
Wishmaster's Avatar
when installing the balancer,,,,how far down do I go? alll the way till it bottoms out on the crank and I cant go anymore?
Old Dec 19, 2006 | 03:15 PM
raul.garcia's Avatar
The bolt and washer determine how far it will go. It's pulley will need to align with the accessory pulleys.
Old Dec 19, 2006 | 06:54 PM
Z28SORR's Avatar
Yes. Please do yourself a favor and buy a Harmonic Balancer Installation tool from your local Auto Parts.
Wrong. The dampener/balancer should be firmly seated against the crank. If the pullies don't line up something else is wrong.
Old Dec 20, 2006 | 07:40 AM
Wishmaster's Avatar
yeah I kinda knew the bolt and washer didnt determine how far it went....thanks for the info...
and just to make sure, I lube the timing seal with oil but do I lube the crank snout and inner of the balancer?
thanks
Old Dec 20, 2006 | 02:49 PM
Z28SORR's Avatar
thanks
Don't think it's required but it couldn't hurt either. Might help with rust down the line.
Old Dec 20, 2006 | 11:38 PM
Mkos1980's Avatar
You want to lube up the outer shaft with oil or greeze and lube the inside of the balancer with antiseize. Put on and use a harmonic balancer installation tool. Press the balancer on till it stops.
Old Dec 21, 2006 | 03:53 AM
One the balancer is installed with the tool (I never said to use the bolt as an installer, my apologies if that's what you thought,) and the bolt is torqued the balancer will be on as far as it will go.
Old Dec 21, 2006 | 05:07 PM
Z28SORR's Avatar
Just thought this might be a little confussing. Wasn't intended as a slam.
Old Dec 23, 2006 | 01:33 AM
None intended, none taken.
We don't always explain things so that there's no confusion, and usually take it for granted that we're understood.
Nov 18, 2023 07:21 PM
eanhl2004
Apr 4, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
smokin5s
Jul 24, 2003 10:47 PM
