Fuel pump voltage
Old Sep 8, 2006 | 02:52 PM
Buck89RS's Avatar
Fuel pump voltage
Where does the fuel pump get its voltage from? Fuel pump relay? Direct from the battery? Or from another source. My car threw a code that said the "Fuel pump voltage too high or too low" Thanks
-Buck
Old Sep 8, 2006 | 09:12 PM
Damon's Avatar
Re: Fuel pump voltage
Voltage is supplied via the fuel pump relay (on the firewall near the brake booster- there are several relays up there that all look the same but do different things like cooling fan(s), fuel pump, MAF sensor if so equipped, etc.)
Where exactly the ECM reads the fuel pump voltage from I don't know.
Low voltage is possible if there is a problem with the relay, wiring, etc. I can't imagine how it could possibly have high voltage, though, since it's just a relay that sends normal battery voltage to the fuel pump.
grabbem88
Mar 18, 2015 01:25 PM
Scottyboy
Feb 11, 2015 10:28 PM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
