Fuel Pump Just Went!
Old Sep 12, 2003 | 03:01 PM
  #16
kandied91z's Avatar
well you have a freak set of pumps or the air up here is that much thicker...
no way a stock pump supports a 10 second car....but if it worked for you then great!
Old Sep 12, 2003 | 05:50 PM
  #17
Racetronix's Avatar
Originally posted by Marc 85Z28
Go with a genuine AC Delco pump! DO NOT, I repeat, DO NOT use an aftermarket replacement type pump. There is no cost difference, and the AC Delco will last. The aftermarket pumps are known for going bad fast - like only a couple of months. In some cases even weeks... Replacing the pump is not a job you want to do twice. The stock pump should work fine for bolt-ons and even a shot of nitrous.
If you insist on a high performance replacement, mount the pump externally.
Where in the world are you getting your stats from?????
Our failure rates are under 1% and we sell LARGE quantities of pumps / kits.
Of the few pumps we get back most have failed due to contamination, rust (common in older cars like the F-LT1's) or being run dry. Either of these conditions will take out a Delco pump just as easily as a Walbro. At least the graded-media filter sock we supply filters down to 30 microns were the factory sock sits at apx. 70 microns.
Price out the factory fuel pump + bucket... it will cost a small fortune. The Racetronix F-LT1 pump assembly (P/N RX-FLT1-FPA) is warranted for a full year and is designed to work inside the factory fuel module (fill bucket). An off-the-shelf Walbro 307 or 340 will not. M.S.R.P. is only $149.99US.
Unless you are in the position such as Racetronix or Walbro to see the big picture it is best to reserve judgment on aftermarket pumps. You cannot use this forum or any other to gauge the failures as most posts are only made when problems arise. For every post about a failed aftermarket pump there are hundreds of people sitting in the background running one without problem. Keep in mind that Walbro manufactures OEM pumps for GM, Chrysler and many other companies. By condemning a Walbro pump you are doing the same in many cases for the Delco branded version.
Jack
Racetronix
PS. I have had twin Walbro’s in my car for over 12 years w/o a single problem. The car sits all winter with a full tank of gas and all is well again in the spring…
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
