fuel problem ?,help please
Old Jul 2, 2005 | 09:28 AM
rdrokit's Avatar
I have an 89 GTA Trans am 350 tpi.
The car will not start when it's cold or warm.If I spray a small amount of starting fluid in the throttle body it starts right up,idles fine and runs perfect.I tested the fuel pressure this morning and when I turn the ignition on the fuel pressure read 32 lbs and when I started cranking the motor over it dropped below 15lbs.when the car starts with starting fluid,I have to give it gas once or it will stall.Once I give it gas once the car idles and holds fuel pressure at 50psi.The car runs and idles great other than the starting problem.Anyone have any ideas what could be wrong?
Roger
Old Jul 2, 2005 | 07:30 PM
91-Z28-L98's Avatar
Re: fuel problem ?,help please
I've had lots of problems with my fuel system and this sounds different than anything I have experienced. It sounds like maybe the fuel pump doesn't prime the system before starting like it should and that the pump only kicks on when the car is running. By the way, giving the car "gas" is a little misleading, as you are really opening the throttle blades and giving the car more air.
If this were your pump, filter, fuel pressure regulator, or injectors, then you would have a lot of drivability issues.
Old Jul 2, 2005 | 07:41 PM
rdrokit's Avatar
I've never experienced this before either, could it be the fuel pump relay or the computer ?Does anyone have any idea what could be causing this?
Old Jul 6, 2005 | 08:52 PM
rdrokit's Avatar
does anyone have any ideas what could be wrong?
Old Jul 7, 2005 | 10:20 AM
Crovax WS-6's Avatar
you are reading 32 lbs, when you click the key on? that sounds a bit low. and when you drive it there are no problems at all? ususally if its a pump problem you will have prolems all the time or you will hear it whining.
Old Jul 7, 2005 | 05:06 PM
rdrokit's Avatar
Just in case anyone has this problem,it was the wires that push into the fuel pump relay not connecting all the way
Roger
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
