found the power draw in my car... need help
Old Feb 18, 2003 | 04:44 PM
stonedchihuahua's Avatar
okay I found the power draw on my 85 camaro it says it is the acc circut which only seems to hold the power lock stuff. I have some of this disconnected.. any idea?? is it probably a switch?
Old Feb 18, 2003 | 04:52 PM
jzajac1's Avatar
You'll need to get a wiring diagram and see what is connected to that circuit. Then you can disconnect one component at a time while you have a meter hooked up, and see when the draw stops when you start disconnecting each individual circuit. A dealer would probably run you a zerox copy of a diagram for free for that acc circuit.
Old Feb 18, 2003 | 04:56 PM
I got one it says power locks... Thats it...
I was using a home made test light with a tail light plug and two wires... thats the one that the thing wouldn't light when it was out
Old Feb 18, 2003 | 05:17 PM
jzajac1's Avatar
The only diagram I have is for a 87 but minus the engine controls everything else should be the same. As I follow ckt 40, it gets spliced into the tail lamp fuse also. I'll just run down the list of where ckt 40 is attached.
Outside power mirror
Lamp in the trunk area
Door Locks
Horn relay
Light switch
LH courtesy lamp
Fog lamp harness connector
That is all that I could trace.
Old Feb 18, 2003 | 05:41 PM
hmm so......
Door Locks
Horn relay
Light switch
LH courtesy lamp
I'll check those out
cmsmith
Apr 11, 2015 09:37 PM
robcarnut
Mar 20, 2015 03:40 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
MJ_Z28
Aug 8, 2002 09:02 PM
HuJass
18
Jun 24, 2002 09:19 PM
