Found New Block Numbers
Old Sep 20, 2003 | 08:28 PM
shwine617's Avatar
I found new block numbers on my 350
the block number i already found was
3970010
i also found
5 M19
D A N
does this tell other information?
thanks
Old Sep 21, 2003 | 03:01 PM
nape's Avatar
The 010 at the end of your block number lets you know it was a high nickel content block. Supposedly they're stronger then other blocks because the nickel makes the iron harder.
They were made between [I think] '70-'80 and came in 2-bolt and 4-bolt mains. You have to pull the pan to check.
You'll need someone else to figure out all the date code info for you though.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
ChrisFrez
Mar 1, 2015 01:33 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
