engine stumbles
Old Mar 9, 2008 | 08:49 AM
mrcamaro1956's Avatar
engine stumbles
Hi, I Have A 1992 Rs Camaro 305 Cid The Problem Is When The Engine Warms Up And I Put It In Drive The Engine Stumbles Then Stalls. I've Changed The Tps- Cap Rotor-spark Plug Wires And Spark Plugs Checked Timinig Nothin Works.also When I Go To Do The Timing . When I Disconnet The Timing Wire ( Grey & Black Wire Passenger Side) The Check Engine Light Stays On . Is This Ok ? How Do I Turn It Off ? There Are No Codes Showing
Thanks For The Help
Old Mar 12, 2008 | 10:19 PM
90rocz's Avatar
Clear codes and reset lights by disconnecting the battery neg lead for a few seconds.
Does it idle a little fast? If it's TBi, while the engine is cold, squirt some carb cleaner aroung the base of the TBi unit. If the idle changes significantly, then the base gasket is bad.
Listen for vacuum leaks too.
Brake_L8
Jan 20, 2015 09:44 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
Lions3
Apr 11, 2003 10:55 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
Dave19yz28
Jan 26, 2003 01:45 PM
