Help!
Old Mar 12, 2008 | 09:21 AM
darkpheonix's Avatar
Help!
I need to replace my rear end because of the previouse owner and I was wondering where i could get a posi for my 90 GTA? Or what cars I could get one out of that are compatable.
Old Mar 12, 2008 | 01:11 PM
jayman350's Avatar
get a 10 bolt out of a 4th gen, it will bolt right up with no modifications needed. the wheels will stick out a little further but when i did it i liked how it looked better
Old Mar 12, 2008 | 05:10 PM
lordmetalz28's Avatar
i personaly built a bulletproof rear for mine. 600$ on parts from randys ring and pinion. and 600$ labor(including subframe connector install) and of course i opted for solid pinion spacers and the cover that takes stress off your main bearings. hope this helps a bit
Old Mar 12, 2008 | 09:50 PM
90rocz's Avatar
I agree, I got a Zexel Posi from Randy's Ring & Pinion for about $330, and some 3.73 gears from a salvaged S10, and a rear cover brace for about $160 that has set-screws to brace the bearing caps, new bearings from Autozone.
I haven't did the axles yet, but Summit Racing or Jegs has'em at decent prices.
Old Mar 13, 2008 | 09:51 AM
If I put the 4th gen rear end in my car will the brace from the transmission bolt up to it or will I have to fabricate something?
Old Mar 13, 2008 | 10:26 AM
Rice Killer87's Avatar
It'll bolt up b/c the 4th gens use the same dumbass setup too.
Guys at GM:
"Lets take all the stress from the rear twisting...AND PUT IT ON THE TAIL SHAFT OF THE TRANSMISSION!!!"
Everyone around him:
"HOLY @*&$ THATS A GREAT IDEA!!"
Old Mar 13, 2008 | 02:04 PM
DW2000TA's Avatar
im doing the same to my 92 vert..you know what they say wider is better and with a 4th gen 10 bolt it alows you to put a wider tire on it too!!!! mo mods needed..bolts up like it was made for it!
Old Mar 13, 2008 | 02:41 PM
1987IROC350's Avatar
Nice to know this about the rear.
I put a 2001 aluminum driveshaft in my 3rd gen when I installed the new 700R with no mods.
