Electric fan problem
Old Dec 3, 2008 | 11:45 PM
MotorHeadJoe's Avatar
I switched from a straight fan in my 3rd gen to the electric fan a while ago. I had it wired to the alternator so it would only run when the car was running, but now it seemed to die down and only barley moves with the car on. Is there anywhere else I could wire it into so it only works when the car is on???
Old Dec 8, 2008 | 06:45 AM
86camaro383's Avatar
the motor is probally burned out. The fans arent designed to be on all the time. When you replace the motor, hook it up to a switch.
Old Dec 18, 2008 | 05:20 PM
1987IROC350's Avatar
Check out these fan kits. I gotta get one because my fans are running the car too cold. I might get the adjustable fan kit.
http://store.summitracing.com/egnsea...alse&N=700+115
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
97z28k&N
Jan 9, 2015 04:58 AM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
