Doors
Old Jan 26, 2003 | 08:57 PM
Patsl's Avatar
Doors
Are 3rd gen Camaro and firebird doors the same, they look it but I want to make sure before laying down any cash. Thanks for any help
Pat
Old Jan 26, 2003 | 11:58 PM
STL REVLIMIT's Avatar
yea the doors are the same. The only difference is maybe in the years and model. Since certian models had door caps to match the body kit. But its just simple work if you get one that doesnt just gotta drill holes.
Old Jan 30, 2003 | 06:34 PM
Marc 85Z28's Avatar
Yes... I've got an 87 TA driver's door on my car. But be warned, they do have some minor differences. Different year Camaros and Firebirds came with different size and shape ground effects. They all have different bolt patterns. When I switched over, I had to fill in the holes left exposed from the TA ground effects. Fortunately that was no big deal, since I was having the car repainted.
Also, the 82-84 and 85-92 are slightly different internally. Window regulators and mounting are different.
Couple more things. DO NOT cut the wiring harness. Remove the door panel and disconnect everything and pull it out the door. And regardless of condition - replace the lower hinge pins and bushings!
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
