Distributer shot?
Old Jul 19, 2002 | 06:44 PM
stonedchihuahua's Avatar
Post Distributer shot?
YEah my car has a **** of a miss and when I put the timing light on it there are about 5 flashes then a pause then 5 then a pause. It does this on all the wires so does this mean my distributer is shot or could it just be the coil. Because all I can think of is the coil not generating enough power so it fires fine 5 times then there isn't enough power to fire again.
Old Jul 20, 2002 | 05:54 AM
firechicken_3's Avatar
Post
the magnetic pickup in the distributor could be bad, you could have a bad distributor cap (contacts are loose), loose plug wires, wires that have internal damage, don't be afraid to tap on the distributor cap, and move the wires a little, to see if makes a difference, its not gonna kill you if you get a little shock from your ignition system, but it WILL wake you up i got bit by an accel super coil once, my hand kinda tingled for about 3 hours
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
currently in pieces, for manual swap
Old Jul 20, 2002 | 09:52 AM
angel71rs's Avatar
Post
Usually when a coil dies, it's dead. You might consider the ignition module if it's an HEI. You can have your coil and module tested at Autozone.
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
maverickmk
Sep 1, 2015 09:17 PM
