Dipstick tube seal on 700r4/Leaking/is it common?
Old Feb 7, 2005 | 05:29 PM
dochtermiatasbrother's Avatar
Is this a common prob? cause i cant get my car 2 stop peeing tranny fluid after it sits a night or 2............ this means no races this thursday if i cant fix her!!!
Old Feb 7, 2005 | 05:59 PM
crazypurgatory's Avatar
Re: Dipstick tube seal on 700r4/Leaking/is it common?
Never Had that problem with my 85 camaro or my 88 Firebird.
There is an O-ring on the inside the transmission.
You need to check to see if it's there or if it's good.
You probably need to take the pan off to check.
I'm sure the the O-ring is bad.
Good luck,
Chris.
Old Feb 7, 2005 | 07:14 PM
JSkeet's Avatar
my car doesnt 'pee' fluid but I have trouble with the dipstick staying down inside the trans. about once a month I'll crawl under the car and shove the damn thing back down, it helps if u have someone under the hood pushing/wiggling on the fill tube as well.
Old Feb 7, 2005 | 07:19 PM
Your dipstick tube should be bolted to your transmission bell housing.
Chris.
Old Feb 7, 2005 | 08:40 PM
Camaro_Boy's Avatar
yeah hes right.. i also had the brakets and it was bolted to the tranny.. i think i have the old one still.. i changed my tranny to manual.. so if u need the clip... let me know
regards
Douglas
Old Feb 7, 2005 | 09:07 PM
TheGreatJ's Avatar
The "o-ring" isn't inside the pan. It's actually a grommet that goes in from the top just to the right side of the bellhousing. You'll have to remove the top right bellhousing bolt and pull dipstick up about 3-4" to get the grommet out and change it. I've seen quite a few of them leaking, but mostly on older trannys.
If you don't bolt the dipstick tube bracket to the bellhousing like you're supposed to, it will work it's way out like JSkeet's.
Old Feb 8, 2005 | 01:24 AM
JSkeet's Avatar
ahhhhh no f***in wonder.... jeezz... son of a bitch....
Old Feb 8, 2005 | 04:11 PM
tks.... i will replace and maybe it will work
Jlo
Jul 29, 2015 03:52 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
dolfan324
Jul 17, 2015 10:34 PM
Catmaigne
Jul 14, 2015 05:17 PM
camaro02DK
Jul 5, 2015 09:24 AM
