cutting springs
Old Jun 14, 2004 | 02:47 PM
buffalo bill's Avatar
cutting springs
is it possible to cut the springs on a 3rd gen camaro?
has anyone ever done it before?
Old Jun 14, 2004 | 03:32 PM
do you cut them at the top or bottom?
and can i cut the front and back( all 4)?
p.s. i am completely retarded when it comes to suspension.
Old Jun 14, 2004 | 04:45 PM
PyRo9862's Avatar
Lowering your car you should get LCA relocation brackets, and just spend the money for lowering springs, they arn't expenisive. Do new shocks and struts while your at it, they have to come out anyway. Throwing in some bigger swaybars, and putting poly bushings in while your suspention is half apart isn't a bad idea either. Ok, your free job just went up to $800 or so, but it pays to do it right, and you will definatly feel a big differance
While your spending that much throw in a wonderbar ($10 or so), and an STB, 3pts start at $130. Stuff adds up quick
Old Jun 14, 2004 | 04:59 PM
IROC-T's Avatar
LOL! you forgot the SFC's
Old Jun 14, 2004 | 10:06 PM
PyRo9862's Avatar
Damnit, add another $300
A good set of tires to $1000
Old Jun 14, 2004 | 10:39 PM
aklim's Avatar
I thought it was a bad idea to cut progressive rate springs?
Old Jun 22, 2004 | 09:24 PM
jconrad's Avatar
Yeah, I also would not recommend cutting the springs. It will change the spring rate, and not for the better, either. lol
Old Jun 24, 2004 | 06:52 PM
slimdawson's Avatar
I didn't know progressive rate springs came on Camaros.
There is nothing wrong with cutting springs. It will increase rate which is good when the springs have less distance to travel. Just take your time and cut 1/2 coil off at a time. Put them back in, and check height. It is harder to make the spring longer than it is to make them shorter.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmdeshon
Dec 12, 2014 10:51 PM
