Compression test to Compression Ratio
Old Nov 10, 2004 | 02:20 PM
bmillington's Avatar
Knowing I have a stock bottom end 350, and aftermarket heads. Can I figure out the compression ratio without taking the heads off and CC-ing them. Compression test gave 180psi, and the engine dosent show signs of wear but has 140K miles. The heads spec sheet say 64cc but not sure how accurate every head is to the specs.
or
What is the stock deck height, bore, and stroke? Whats the stock pistons volume or are they flat? How thick is the head gasket. Is there a site with all this info?
Thanks,
Old Nov 10, 2004 | 08:45 PM
86z28nos's Avatar
Re: Compression test to Compression Ratio
Its real hard to say with out knowing your cam and piston size just a guess should be around 9.5 to 1 hope this helps
Old Nov 10, 2004 | 11:12 PM
raul.garcia's Avatar
or
Thanks,
Try a search for "compression calculator", you'll need to know bore diameter, gasket thickness, etc...
Compression readings aren't used to calculate the compression ratio.
Old Nov 11, 2004 | 02:24 PM
Damon's Avatar
An old "rule of thumb" is to divide the compression readings by 19. This is only for the most rough of estimates and not to be used as a definitive answer. However, if you have a modest cam (not some big lumpy sucker) and you're pushing 180 then you'll probably be right around 9.5:1. Both the old "19" trick and my personal experience tell me that's probably about right.
KYWes
Jun 14, 2022 06:52 AM
asilomar244
Jul 12, 2015 05:53 AM
dylan1303
May 22, 2015 12:24 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
