Are 3rd and 4th gen alternators interchangeable?
Old Nov 9, 2004 | 04:31 PM
Mullet Z28's Avatar
Will an alternator off a '92 fit an LT1?
Old Nov 9, 2004 | 07:19 PM
Dave89IROC's Avatar
Re: Are 3rd and 4th gen alternators interchangeable?
I think the mounting ears are different
Old Nov 9, 2004 | 08:14 PM
Zepher's Avatar
In GM-High Tech, a guy is installing an LT1 into his 89 Formula and used an L98 alternator since it was smaller and lighter. Looking at teh two, the mounting ears look the same.
Old Nov 10, 2004 | 05:48 AM
thezisking's Avatar
I'd say no. Third gen alternators are 105 amp and 4th gen are 140 amp. I'm going off of autozone's web site. The part number for the forth gen is: 1429-6-7 and the third gen is: DL1341-5-11. Hope this helps!
Old Nov 10, 2004 | 07:17 AM
Zepher's Avatar
Part numbers are going to be different because they have different connectors and amp ratings. But you can change the connector on the harness and up the amp rating on the alternator with a kit or having a shop do it. the alternator that the guy in GM high tech was a Promaster that puts out 90amps at idle and 140amps at cruise
Old Nov 11, 2004 | 02:27 PM
Mullet Z28's Avatar
OK, so the mounting ears are the same. Thanks.
ad356
Apr 11, 2015 11:12 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
formula79
23
Jun 20, 2002 01:42 PM
