Cleaning MAF sensor
Old Jun 17, 2006 | 09:34 AM
Black305RS's Avatar
Cleaning MAF sensor
whats the procedure for this? i know mine is gunked up because my burnoff relay went out and i didnt fix it for 2 days and its causing a rough idle on cold start only, and unplugging it corrects the idle. i really dont want to shell out 165 dollars for this part. so any help would be appreciated.
thanks
Sean
Old Jun 17, 2006 | 09:49 AM
teke184's Avatar
Re: Cleaning MAF sensor
carb/choke cleaner
or some electrical contact cleaner from any store.
jsut spray gently
Old Jun 17, 2006 | 01:14 PM
IROC-T's Avatar
Originally Posted by teke184
carb/choke cleaner
jsut spray gently
and "DONT TOUCH " that wire in the middle. If you break it you'll need that new one, it's very delicate.
If your relay is working now it should burn off what little contamination that has stuck to it, that what the burn-off does. If you do feel you need to clean it just be careful.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
3TAS4ME
Apr 15, 2015 02:24 PM
QuickSilver02
Apr 7, 2015 11:12 AM
pete53
Dec 9, 2014 07:31 AM
