Changing thremostat- Please help!
Old Jun 22, 2005 | 12:54 PM
'86 350's Avatar
I know this may be a stupid question, but oh well.
The problem is I'm changing the thermostat in my car and coolant wants to poor out of the upper hose. How do I remove the thermostat and thermostat housing without coolant going every where!?!? Please help quickly!
Old Jun 22, 2005 | 01:01 PM
Tru2Chevy's Avatar
Re: Changing thremostat- Please help!
You are going to lose some coolant unless you can completely block off the lower hose, and then keep the upper hose up in the air.
- Justin
Old Jun 22, 2005 | 01:04 PM
'86 350's Avatar
Okay well the lower hose is still connected to the engine, and the upper hose I need to take off. How much coolant will I lose if I just let the upper hose dangle? Will it be just what's in the hose or will it be a lot more then that?
Old Jun 22, 2005 | 01:08 PM
Tru2Chevy's Avatar
I mean you could put some sort of clamp on the lower hose to keep coolant from running through it. Otherwise the pressure will push some coolant out of the thermostat housing when you remove the thermostat.
- Justin
Old Jun 22, 2005 | 01:17 PM
'86 350's Avatar
How much coolant though? Less then a quart or so?
Old Jun 22, 2005 | 01:27 PM
Tru2Chevy's Avatar
I dunno...you will lose any coolant in the hose, and the upper part of the radiator.
- Justin
Old Jun 22, 2005 | 01:28 PM
chevyz28racer's Avatar
just tie the hose or have someone hold it straight up... it matters how fast you can move haha
Old Jun 23, 2005 | 12:02 AM
Runin2Nite's Avatar
y is it an issue if u loose coolant u wont loose much. do it while the car is cold so the thermostate is shut.
Old Jun 23, 2005 | 06:16 AM
'86 350's Avatar
It's an issue becasue my parents freek out when things like this get all over the driveway or the garage floor. I did et it though, thanks guys.
Old Jun 23, 2005 | 11:38 PM
Runin2Nite's Avatar
i feel ur pain...... what temp them. did u get???
Old Jun 26, 2005 | 01:39 PM
'86 350's Avatar
I got a regular 180* thermostat. I got a hi-flow one though from Mr Gasket. The other one actually wasn't stock, it was also an aftermarket, 180* thermostat. However, it was stuck closed so that's why I'm replacing it. Thanks for the help guys.
96SilverRam
Nov 20, 2016 11:19 AM
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
