Centerbolt Question
Old Apr 5, 2006 | 08:13 PM
LesPaulGoth's Avatar
Centerbolt Question
Right now I have L98 heads on my IROC, centerbolts. I want to get these BRO-1021001 @ summit. Will I still be able to bolt these non-centerbolts on? Or do I HAVE to get centerbolt heads to replace my stockers?
Old Apr 5, 2006 | 09:13 PM
91Z-28's Avatar
Re: Centerbolt Question
I've seen centerbolt to perimeter bolt conversion kits, even GM offers one I believe.
Old Apr 5, 2006 | 10:20 PM
So you do need a conversion kit...wouldnt that involve drilling and tapping holes into the block? Anyone have a link to this kit?
Old Apr 5, 2006 | 10:49 PM
fbodyguy86's Avatar
the heads should bolt to the block the intake manifold bolts are different on the 2 middle holes on each side. they are drilled and tapped at a different angle you could have the manifold redrilled for the new heads or if they dont fit get one that will. i believe most aftermarket manifolds will fit both styles of heads
george
89 RS t-top
converting from TBI to TPI
Old Apr 6, 2006 | 11:42 AM
Z28SORR's Avatar
Your confusing the Head mounting with the Valve Cover mounting. When you say "centerbolt" that means the Valve Cover mounting, 4 center bolts, as apposed to 4 perimeter bolts. You can get a spacer that converts the perimeter pattern to center pattern.
The Head mounting is the same, only difference was explaned by fbodyguy86.
Old Apr 6, 2006 | 03:26 PM
Alright, I was confused by what 91Z was saying. I plan on getting different valve covers anyhow. I thought that he meant there was a kit with a template and a drill and tap..or whatever, but I got it now. I'll look into it, thanks guys
Old Apr 6, 2006 | 05:16 PM
91Z-28's Avatar
My mistake, I saw centerbolt and assumed right away you were talking about valve covers. I figured you bought some perimeter bolt heads and currently have centerbolts.
Old Apr 9, 2006 | 12:01 PM
krazzycowgirl's Avatar
Ok this is confusing on so many levels.
Ok If someone wanted to go from Center bolt Valve covers to Outer bolt Valve covers on the same set of heads (which do not offer both options) then you can pick up a kit from Summit made by trick flow TFS-31500811.
As for Going from heads that are centerbolt to outerbolt it doesnt matter.
With those heads you should be fiine.
Even though I spent a little bit more money on mine.
Dont forget when you get those heads to see if your stock pushrods will work if they do order another set if not still order another set.
I am in a middle of a 355 build myself with AFR heads.
Old Apr 9, 2006 | 10:12 PM
Yeah, I have to get on the phone with Brodix and see what length they recommend...friend of mine snapped a pushrod after his top end rebuild, so I'd be paranoid...even if the length was correct, they are 16 years old and with making 100-150 more hp than stock I'd want something chromoly/heat treated.
Thanks you guys/girls
Old Apr 9, 2006 | 10:16 PM
Yes make sure, Also find out if those heads use guid plates if do make sure you get pushrods that are made for those.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
