Will 3rd and 4th gen seat brackets interchange?
Old Apr 8, 2006 | 07:42 PM
FASTFATBOY's Avatar
Just like the title says..........will they?
David
Old Apr 9, 2006 | 11:47 AM
krazzycowgirl's Avatar
Re: Will 3rd and 4th gen seat brackets interchange?
They should
I know that 2nd gen to 3rd gen do not work or 3rd to 2nd unless you drill.
But If I remember right the 3rd to 4th & 4th to 3rd do work
Old Apr 9, 2006 | 11:58 AM
transAMdriv3r's Avatar
they do, they have the same upolstery
Old Apr 9, 2006 | 12:35 PM
Aklaim's Avatar
The seats are direct swaps! No need to take the seats off the brackets, just inbolt 4 bolts (remove wires if powered) and then remove seat, and drop in 4th gen seat, bolt down (hook up wires if ya got em). Fronts and rears are direct swaps.
Old Apr 9, 2006 | 03:06 PM
Dave89IROC's Avatar
IIRC, the third gen ones are a little shorter then the 4th gen ones
Old Apr 9, 2006 | 07:28 PM
Aklaim's Avatar
No. Ive done the swap myself..... it will take you 20 minutes to remove the old 3rd gen seats and bolt down the 4th gen seats. Everything lines up 100%.
Old Apr 9, 2006 | 08:08 PM
Its the 2nd gens that are shorter & you have to redrill for 3rd gen seats.
Old Apr 9, 2006 | 09:18 PM
Dave89IROC's Avatar
I'm pretty sure if you run 4th gen seats in a third gen, the 3rd gen brackets make it sit lower
Old Apr 9, 2006 | 09:34 PM
ws6transam's Avatar
Mine didnt.
They sure feel the same to me, and I've got 16 years and 140,000 miles of seat time in my '84.
I can swap seats in & out in about 12 minutes. Mine current seats are from a 1994 Formula.
Old Apr 9, 2006 | 10:00 PM
2fbodies2NV's Avatar
They're the same. Direct bolt in. No difference in height either.
Old Apr 9, 2006 | 10:19 PM
Nope I have done this swap too, Along with my brother in law doing the 3rd gen to 2nd gen swap.
I also did this swap with a 96 S10 pick up its a direct bolt in as well
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
JoshGuitar
Jul 23, 2002 06:20 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
formula79
23
Jun 20, 2002 01:42 PM
