Carbed 305 to Carbed 350
Old Jul 21, 2002 | 08:53 PM
BADAZZ_Z28's Avatar
Post Carbed 305 to Carbed 350
I have an '86 z28 and as soon as i get my car back from the shop (it was stolen and the whole dash got torn off) i want to drop a 350 in. What would i need to buy/replace to do this. This is my first swap. please help...
Old Jul 21, 2002 | 09:18 PM
IrocSS85's Avatar
Post
nothing. just the eng. everything will swap onto it. what kind of carb. do you have now?
what kind of power will the 350 be making? you can prolly even use the same carb. as the 305 unless the 350 will make alot of power. if its under 300 horse, then you shouldnt have to change anything else.
but, you will proly break the bolts off the exh. mannifolds so Id get some headers and an aftermarket exh. system to go w/the swap. while you have the eng. out, nows the time to make sure your eng. mounts are good (they typically sag and have some play in them when they are old/wornout) and the harness is good. plus make sure that when you get the new eng. in, that the starter wires are out of the way and protected from the exh. system's heat.
good luck.
chris
1986 Iroc Z
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solidcam .501I .510E, 4gen rear w/3:73 posi, girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd 6al, coil, dist., mallory wires.13.34 @102mph best w/that combo. have trick flow heads and tighter conv. to put in currently.
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Jul 21, 2002 | 09:40 PM
BADAZZ_Z28's Avatar
Post
i had plans of adding an aftermarket exhaust and headers anyway. Should i wait till i get the 350 in to put in the exhaust system (not headers yet) or can i put the exhaust on while the 305 is still in. The 350 w/ definately be below 300 horses but i was planning on getting a holley 600 anyway. Thanx
Old Jul 21, 2002 | 09:45 PM
86IrocCamaro's Avatar
Cool
well if u put on the exhaust with the 305 in there it would not bolt up to the exhaust after the 350 swap and the headers. It should with just the 350 but not with the headers
3RD Generation Camaros 0wN your ***!
Old Jul 22, 2002 | 12:30 AM
stanghunter211's Avatar
Post
Wait till you get the 350 for exhaust and so on. Will be alot easier when you have the blocks out! If you don't need smog checks and all that good stuff where you live, then it should be an easy swap. If you do, then the computer will need to be reprogrammed to support a 350. It will not give the 350 the right signals and so on, those of a 305 would not be good for a 350. Hope that helps!
Will
'86 Z-28 305 c.i. LG4
Rochester QuadraJet 4bbl
Flowmaster 80 series Chrome Tips
Dual Snorkel Air Cleaner
K&N Filter
Michellin P215/65/R15 X-Radial Plus
Lots of Mods on the way
Pioneer 4"x6" dash
Pioneer 6"x9" rear
Alpine 8" Type S in bandpass box
Alpine Amp 300x1 bridged
Sony 4000X- x-Plode Deck 50w x4
Soon to be sporting Hooker SuperComp Shorties, CompCam Xtreme 256H, Edelbrock Performer EGR, World Sr Torquer 305's, DynoMax Super Converter, and American Thunder 3" Cat-Back !!!
http://camaroz28.cardomain.com/id/stanghunter211
Old Jul 22, 2002 | 08:10 AM
Perry93TransAm's Avatar
Post
Not sure exactly why 86 Iroc thinks the exhaust on a 305 wouldnt fit a 350 (please elaborate, I think I'm missunderstanding you) But anything that bolts onto a 305 will bolt onto a 350 (chevy). Since youre carbed a rod and jet change would be all youre needing on the carb end, but removing the electronic quad will make things easier to tune. (unless the law requires you to have it). The only advantage of waiting til the engine swap to do the exhaist would be setting the headers in then lowering the engine down, but of note you would also have all of your leaks,bends, and other annoying bolt-up problems already solved for your 350.
Perry
Kawi
Sep 28, 2015 09:01 AM
HAWG
Sep 25, 2015 11:41 AM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
