View Poll Results: Carb or EFI
Go carbed and save a few bux.
24.14%
Stick with the EFI, pinch my pennies and go in the original direction.
75.86%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
To carb or not to carb....
Old Feb 14, 2006 | 12:02 AM
  #151
damien8618's Avatar
Re: To carb or not to carb....
this is a car messege board and we have college dorks who know nothing about cars, y am i wasting my time u guys need to learn about cars before comming on here saying bull****
Old Feb 14, 2006 | 12:03 AM
  #152
2fbodies2NV's Avatar
umm, no 255 is way under 150. duh . 150 is way better than 255. prove that 255 is better than 150. show me proof.
  #153
Sweetred95ta's Avatar
Originally Posted by damien8618
isnt 255 over 150 mph, bone head?
I was wrong. Z rated is to 149 mph and over. Actually, W and Y ratings are better.
Z=149 MPH, 240km/h and over, Sports Cars
W=168 MPH, 270km/h, Exotic Sport Cars
Y=186 MPH, 300km/h, Exotic Sport Cars
  #154
damien8618's Avatar
the theory of realitivity is so commen sense i realized it before i was tought it in school
  #155
thirdgenrallysport's Avatar
i would have no problem if you never visited this board again.
Old Feb 14, 2006 | 12:04 AM
  #156
5-7's Avatar
5-7
disc/drum is the best setup because drum brakes offer greater stopping power but u have to use a disc brake in the fron for straight line stopping. drum brakes are self energizing which means the shoe is pushed into the drum then the drum grabs onto the shoe creating a wedging action. this is y when cars were drum/drum they had maual brakes and when disc brakes came out they had to use a power booster
you're name is Damien and you are the biggest retard I have ever seen posting about cars. You don't know anything because your pea brain is still stuck in the 50s. Drum brakes suck you ****head, they don't have half the force applied or anywhere near the heat dissipation a disc setup has. Maybe if you went to college, studied engineering (actual engineering, not some meatheaded, GED-accepting tech school for tards) you'd know this. Just for the record, the only racers that still use carbs are drag racers. Every other form of racing from IRL to Rally and LeMans uses EFI engines. EFI is far more reliable, has the ability to correct for numerous environmental factors AND error as well as greater efficiency because a computer can do a lot more as far as adjusting timing and fuel delivery for temperature/pressure/humidity than some mullet-toting retard holding a wrench pissing around with a carb. Drag racers can still rely on carbs because after their 7 seconds or less of running is up, they can play around with them. A computer is far better for long duration races. Get a clue and shut the **** up. The world needs less ignorant retards that think because they don't get how something works its wrong and bad.
  #157
damien8618's Avatar
what is a duo servo drum brake?
  #158
iz thet wi u spel so gud to
Old Feb 14, 2006 | 12:05 AM
  #159
5-7's Avatar
5-7
how about you explain what numerous physicists spent a good part of their lives trying to figure out? Oh wait, explanations are too much for you, you just like claiming you know things when you don't. get out of here, inbreed. You probably think the theory of relativity has to do with your unbranching family tree
Old Feb 14, 2006 | 12:06 AM
  #160
5-7's Avatar
5-7
I think you mean, dual, and it's an archaic piece of **** braking system that uses 2 servos (likened to pistons on a superior disc brake system) instead of one. For a little extra "clamping" power, and no more heat dissipation. What's an MRI? idiot
  #161
damien8618's Avatar
drum brakes offer more stopping power and disc brakes offer more heat dessipation, disc brakes arnt self energizing u bone head, u need to learn about the basics of cars before u get into high tech stuff
Old Feb 14, 2006 | 12:07 AM
  #162
5-7's Avatar
5-7
Are you done making up terms? Do you even know what heat dissipation is? Go learn something about thermodynamics and cooling. The fins on a drum aren't anywhere near as effective as the open air cooling and slotting of a disc brake. There isn't a drum brake car around that can stop within 100 feet of a performance oriented disc brake system
Old Feb 14, 2006 | 12:08 AM
  #163
Like I said "Yesterday I couldn't even spell Mechanic, today I ARE ONE !"
  #164
ok please tell me you are from arkansas.
Old Feb 14, 2006 | 12:09 AM
  #165
5-7's Avatar
5-7
with that said, go pound sand, and pigs, in your trailer, disgusting retarded hick.
