Cam
Old Jan 9, 2003 | 10:51 AM
1984camaroz28's Avatar
Cam
Ok i just bought a set of 2.02 head 60cc champer my car will make 10.5 to 1 what cam whould u guys suggest. Once again money is no object
Old Jan 9, 2003 | 10:54 AM
sry ...the car will turn 6grand
Old Jan 9, 2003 | 10:56 AM
Sitting Bull's Avatar
Roller or flat tappet?
Old Jan 9, 2003 | 01:28 PM
Roller
Old Jan 9, 2003 | 04:04 PM
2IROC's Avatar
comp extreme 110LSA .50 236 242 ........520 540
Ive got the part number if you need it. Its a pretty nasty cam. Thats with 1.5. If you 1.6 rockers it will bump the lift to like ...576.
Old Jan 9, 2003 | 07:17 PM
my 2.02 heads dont have screw in studs can i still use roller rockers
Old Jan 9, 2003 | 07:37 PM
2IROC's Avatar
Sure...I used them on my car in the past. They were press in.
Old Jan 9, 2003 | 07:40 PM
2IROC's Avatar
If you get to nasty of a cam.... you should take your heads in and have them machined for screw in studs. It doesnt cost that much. Maybe 100 bones with studs.
so i need guide plates rite
Old Jan 9, 2003 | 07:54 PM
2IROC's Avatar
What kind of heads do you have? What are the specs?
Old Jan 9, 2003 | 10:51 PM
TheGreatJ's Avatar
If you go with roller rockers you'll either need to get guide plates and hardened pushrods or buy the "self aligning" rockers which cost quite a bit more. Since you're changing the heads anyway I'd go ahead and get screw in studs just so I'd know they won't ever pull out, but that's just me.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
