A/C removal !! ??
Old Aug 3, 2003 | 04:22 PM
  #16
I EAT T/A's Avatar
Originally posted by Brit Iroc
EVAP coil?
The coil in which the freon flows and the blower motor pushes air through the coil into the car. Its under the black cover connected to the dryer.
Old Aug 3, 2003 | 05:16 PM
  #17
Brit Iroc's Avatar
Aahh!. Just took all the pipes out so all thats left is that box with just the ends of two pipes protruding from it. Found some rubber sleeving in the garage to cover and seal the ends of those and thats it. Looks ok.
Old Aug 4, 2003 | 11:26 AM
  #18
82355's Avatar
Pulling off your AC isn't going to gain any horsepower. When the clutch is off it is just an idler pulley, and Freon is cheap (R134a anyways). All you need to convert the sytem is the low side fitting, which is a $5 conversion fitting. And unless your building a drag car out of it 18 pounds isn't that big of a deal.
Martin
Old Aug 4, 2003 | 02:21 PM
  #19
shwine617's Avatar
my car takes R-12 so i thought u need a new compressor to convert it to r-134a
Old Aug 4, 2003 | 02:51 PM
  #20
Dirt Reynolds's Avatar
The entire AC system, condenser, compressor, lines and so forth, weighs only 18 lbs? Is that scale you used accurate?
Old Aug 5, 2003 | 07:30 AM
  #21
Brit Iroc's Avatar
Tried a different set of scales. Does this sound better- compressor- 18lbs, condenser, lines and brackets- 4lbs, the rad- 2lbs. 24lbs total. Sounds even better to me!.
Old Aug 5, 2003 | 09:12 AM
  #22
shwine617's Avatar
so what i want to know, if I do it, is it worth it?? does it help track times? if so, by how much?
Old Aug 5, 2003 | 09:49 AM
  #23
82355's Avatar
No you don't have to replace the compressor, who ever told you that is full of ****. All you have to change is adding conversion fitting to use a R134a Manifold Guage Set. It is cheap, I did it to tractors all summer long and have done it to my 90 IROC-Z along with numerous cars at school. In fact on my IROC and the service truck at the John Deere dealership all I did was install a low side conversion fitting and filled it up with Freon. Once again just leave it on the car.
Martin
Old Aug 5, 2003 | 11:26 AM
  #24
Brit Iroc's Avatar
If you take it off all you'll get out of it is the advantage of weight loss. Very minimal power gain. Just look at the big picture. Mine came off with all the emissions stuff when I put ally heads on it. I lost over 70lbs in weight on the front end and gained X amount of power. If you use the car at the strip thats gonna help.
Old Aug 5, 2003 | 11:52 AM
  #25
shwine617's Avatar
its not only that my a/c needs to be charged, it only blows out of the defroster vents, so that could be a major problem too.
Old Aug 5, 2003 | 02:19 PM
  #26
82355's Avatar
Not really, blowing out of the defroster vents is default mode. Probably a vacuum leak, should be a simple fix.
Martin
Old Aug 5, 2003 | 03:08 PM
  #27
shwine617's Avatar
yea, but there is so many vaccum lines, I don't know where to start.
Old Aug 5, 2003 | 07:52 PM
  #28
shwine617's Avatar
if the heat and A/C is coming out othe the defroster only, then what tips would you have on fixing it?
thanks
Old Aug 5, 2003 | 08:22 PM
  #29
I EAT T/A's Avatar
Your entire vent system is based on vacuum. Behind your vent control dial there are 5 or 6 different colored lines and they are vacuum lines. They move your vents....
You'd have to take some of your dash apart to access the lines.
Hope this helps!!
Old Aug 6, 2003 | 01:44 PM
  #30
shwine617's Avatar
well, nevermind then, there goes the A/C system...anyone want to buy it?
thanks
Aug 5, 2015 08:35 AM
MikeWhitener
Aug 2, 2015 06:17 PM
4586
Jul 31, 2015 06:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Jul 17, 2015 02:47 PM
