bottom shock bolt TQ spec? what is it?
Old Apr 5, 2004 | 10:16 PM
Wishmaster's Avatar
what the torque is for the bottom bolts. The book says 70ft lbs That cant be, thats just way to much, if I was to put that much torque on the bottom bolts the lock washer would open up and not be worth a damn and would smash the rubber bushing on it. The tq for the top mount bolt is only 13 ftlbs.
anyone know?
Old Apr 5, 2004 | 10:22 PM
TheGreatJ's Avatar
As tight as you can get it with a 3/8" drive ratchet, or fairly tight with a 1/2" drive. That's as close as I can get you.
Old Apr 5, 2004 | 10:24 PM
Wishmaster's Avatar
the top spec is correct but I highly doubt that 70ftlbs is right for the bottom bolt.
Should I just tighten it till the lock washer closes up flat and be done with it?
When you say tight as I can get it, do you mean without crushing the bushing?
Old Apr 6, 2004 | 01:12 PM
TheGreatJ's Avatar
The lower shock mount should have a "shoulder" bolt which will only tighten so far. Tighten it as far as it'll go.
If it's not a shoulder bolt, tighten it till the bushing compresses a little and then stop. Make sure the lockwasher is flattened. I'd advise loctite in this instance.
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
