basic 3rd gen advice
Old May 27, 2003 | 10:15 PM
  #16
Nitromethane's Avatar
I'm running 13.88's naturally aspirated with 392ft lbs of rear wheel torque and 225rwhp, following specs:
Dacco Detroit 2500 stall torque converter (best thing in the world, I also had a B&M Tork Master 2400 when it ran 14.4's but blew transmission)
1.6 Roller Rockers
10.2:1 pistons (rebuilt the motor last year)
TB Airfoil
Underdrive Pulleys (Crank & Alternator)
Cheap crappy paper filters
Cut out air box n routed a/c duct from grille to air box
Lakewood LCA's
Polyurethane torque arm bushing
Removed all emissions equipment
3" Exhaust cut out
Rear disc posi
May have forgotten some things but oh well, went 12.88 with a 100 shot of n2o, so exactly 1.002 seconds off my n/a ET
I haven't installed the headers yet but they do wonders for throttle response, friend of mine commented on how smooth my off-idle accellaration is, whereas his car has headers, if u so much as tap the gas pedal the car jolts forward, very very responsive.
Don't waste your time with a 305, once you've had a 350, you won't want a 305 ever again so just start with the good motor. TPI's make torque, that's all I can say.
Have fun!
Old May 27, 2003 | 10:32 PM
  #17
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
1.6 Roller Rockers
TB Airfoil
Lakewood LCA's
3" Exhaust cut out
Rear disc posi
Have fun!
Wow. I wonder what a stealth ram would do for your torque curve. The problem I found i had when I was TPI is I made impressive 1/8th times but cause TPI hits a brick wall at 4400-5000 rpm my 1/4s were always lame. What kind of 1/8th and 60s do you turn. ALso with nearly 400 lbs of torque what kinda traction do you get?
Old May 28, 2003 | 08:32 AM
  #18
Greed4Speed's Avatar
dynomax sucks and is very restrictive.
Not true. Try the ultraflows. Flowmaster has nothing on them for low restriction and maintained velocity. You can look straigt through the muffler, can you on flows??? No.
Old May 28, 2003 | 03:15 PM
  #19
Screamin95's Avatar
I say get an 89 TTA! One hella car!
wytblur
Aug 5, 2002 02:03 PM
19redta96
Jul 23, 2002 12:25 PM
stars1010
Jul 15, 2002 03:51 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
