another question please..
Old Sep 14, 2002 | 01:50 AM
citizendan1st's Avatar
Question another question please..
Im assumming the following is in the prober order....
1.set timing...
,and its safe to say my timing could be anywhere between 6 degrees over to 10 degrees?depending on my mods and the like?
2.set base idle
3.set tps
4.obviously at any point do tune up...
just making sure..
thanks again?
Old Sep 14, 2002 | 10:01 AM
aklim's Avatar
Post
So far so good. However, once you set the things, you don't have to reset it unless you are changing your timing or base idle speed. Timing is 6 deg. If you change it, it will affect timing at all points. Say if you wanted more timing down low, it will also affect timing up there where it may cause detonation. For instance, my heads wake up at around 3000 - 5000 pm. I would have the EPROM configured to have more timing down low than when it is in that range because it might ping. The EPROM was told to expect 6 degrees base timing and when it figures it has 36 deg total timing, it is advancing 30 and assuming you have 6 base. Set it to 10 base and it will still think you have 36 deg when you actually have 40.
Old Sep 14, 2002 | 09:27 PM
Z28ROC's Avatar
Question
Are you disconnecting the black and orange wire (if I rember right) on the passenger side firewall, before you set your timing?
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Old Sep 15, 2002 | 01:26 PM
yes i did dissconnect the advance line before timing...
and my fans comeon with ignition....and i believe i have a stock thermastate....190?..so i 160 would definatley help it stay cooler right?
thanks again everyone...
Old Sep 15, 2002 | 04:17 PM
irocbob89's Avatar
Sounds like you got everything figured out pritty good. Just a little helpful hit, when you start the engine(if you havent already) make sure you have oil pressure. I was a dum**** and forgot to check that after i started the engine and fryed the rings, so i have to rebuild it again. I didnt prime the oil pump. Just trying to prevent someone from going through what i went through. Good luck
Bobby
Old Sep 15, 2002 | 04:57 PM
brodyscamaro's Avatar
ttt
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
