Another Overheating Problem
Old Jul 22, 2004 | 12:13 AM
firebirdjosh's Avatar
First off, my V6 has been leaking coolant ( a drop or two max) for a year since I got it and never wanted to bother with it. I don't know if thats related at all but I just thought it should be mentioned. Anyway, my car always runs about 180 degrees on short trips. Today it shot up to 220, and then went into red around 260 degrees. Literally 10 seconds later, it was back down to 220 degrees and ran a bit hot the rest of the ride. Then I get out of my car and my radiator or its hoses were hissing. Then some steam came off of the passenger side of the radiator. I don't know if a sensor is shot or what. Where should I start to find the problem? Just check where the leak is coming then replace it? Where can I find hoses and the radiator and what should I be spending? Thanks!!!
(Of course this happens to me 4 days before I'm going to repaint it!)
Old Jul 22, 2004 | 12:44 AM
IROC-T's Avatar
Re: Another Overheating Problem
If you are still running the stock plastic tank radiator it is probably time to replace it. They tend to start cracking after a few years. Don't have it repaired with a new tank(plastic) you would be better off getting a solid metal radiator. They cost alittle more but well worth it.
Old Jul 22, 2004 | 10:38 AM
Ok, now I'm also thinking its the thermostat from what I was told from friends. How do I replace that? Also, how much am I looking for a new metal radiator and maybe hoses? Thanks!
Old Jul 22, 2004 | 02:10 PM
IROC-T's Avatar
The radiator and hose's are probably going to be about $150ish.
go to TGO do a search for the thermostat,it's not hard once you see how it's done.
Old Jul 22, 2004 | 02:34 PM
I think the radiator is dead. I can smell the antifreeze evaporating off from a leak. So Im getting a new thermostat and refilling the system. If it still overheats looks like time for a new radiator... yuck.
Old Jul 22, 2004 | 03:52 PM
Rice Killer87's Avatar
Go out for a short drive and let the car heat up,then head home. With the car running,look around the radiator and hoses for leaks and to make sure the fan is coming on. If you dont see any leaks,shut it off and watch/listen.
hope that helps
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
