Another Disc to Drum Question
Old Mar 15, 2004 | 04:30 PM
slayer6x6's Avatar
I picked up a 9 bolt disc brake rear for 60 bucks over the weekend. Im gonna put it in on thursday, but I had a question with the prop valve. The dealer wants 80 bucks for the valve and the speed shop has an adjustable aftermarket valve for 40. My question is that does the third gens use a combo valve that contains the metering valve also? Are the aftermarket ones a PITA to adjust? What do you guys think I should do?
Old Mar 15, 2004 | 07:32 PM
TheGreatJ's Avatar
The 3rd gen prop valve controls brake bias as well as isolating the front left/front right/rear brake "channels." I've seen people simply put a T in the front line and put the aftermarket valve in the rear line and get great results that way, but it's a little less safe since the front wheels aren't isolated from each other.
The aftermarket valves are usually more trouble to plumb than they are to adjust.
Old Mar 16, 2004 | 12:22 PM
slayer6x6's Avatar
Ill probably just spend a few more bucks and save my self the hassle. Thanks for the advice.
Victor Lamb
Aug 26, 2017 02:52 PM
grabbem88
Feb 17, 2015 07:49 AM
guyomatic
Sep 11, 2002 02:11 AM
sseeya
Aug 7, 2002 09:07 AM
Chrisdude
Jul 24, 2002 02:25 PM
