Drum brakes with Draglites
Does anybody know if 15X10 Weld Draglites will fit on drum brakes?
SSEE YA,
Mike Glick
97 SS #2476
12.678@110.49
383 in the works!
SSEE YA,
Mike Glick
97 SS #2476
12.678@110.49
383 in the works!
of course they will,after all,cars had drum brakes before disc.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Dirk
1997 TA A4
The RacinLT1
RacinLT1 pic's
13" rims may have problems fitting over 14" drums but I doubt you'll find any car with drums that a 15" rim won't fit.
Rims will fit over drums much easier than they will over disk brakes. The extra room that the calipers take up limits how far a rim can be installed.
With drums, if you didn't have inner fender/springs/shocks etc in the way, the hub of the rim could be right on the outside of the wheel (10" rim with 9" backspace).
You'll still need the longer wheel studs for Draglites since it has a thick hub.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.617
Member of the Calgary Drag Racing Association
461 big block
Best 60 foot: 1.617
