89 RS Ignition Problems?
Old Dec 16, 2003 | 07:13 PM
86305Z28's Avatar
Aight my car will start up 2 times in a row....but then on the 3rd, 4th, 5th, 6,th try to start it nothing happens at all.
The key is the type with the electronic security piece on it. On the black security piece theres a "fin" on each side. One side looks good and the other side isnt as big, like its worn down. Do those "fins" make contact with some metal on the inside to deactivate the security and start the car?
The weird thing is i have a spare key and it does the same starting thing.
Any suggestions?
Old Dec 16, 2003 | 11:38 PM
90rocz's Avatar
That's the "PASS-KEY" Antitheft system, if they don't function it won't start at all. Each key has a specific resistor inside that must make contact to complete the starting circuit. Each car is different.
Can you pull one of the spark plugs and see what it looks like??
I'd say it isn't getting enough fuel to the injectors...if the plugs are clean and dry I'd be right. If they're wet and black, it's getting too much fuel..
Has the fuel filter ever been changed??
Can you check fuel presure by installing a gage to the valve on the fuel rail??
Old Dec 18, 2003 | 05:15 PM
86305Z28's Avatar
now i know its called a Pass Key n not "fins" lol
but i fixed the problem, there was a wire inside the ignition that broke off, replaced the wire n now it starts up all the time.....
thanks for the help tho
liamcg97
Nov 25, 2019 05:55 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
