'87 ECM in a '92 RS
Old Dec 10, 2003 | 11:52 PM
  #16
Zepher's Avatar
Originally posted by 90rocz
Well ,I've seen an '88 w/o it...
Was it stock?
All the 88's I've seen have it, and it's in the programming of the 86-88. 89 programming doesn't have it in there.
Old Dec 10, 2003 | 11:53 PM
  #17
Zepher's Avatar
It could be the later models of 88 with it deleted, but I've never seen one.
I know in a Firebird Reference book, it says 88 GTA's had VATS (Passkey Anti-theft) but my friends 88 GTA didn't have it, that was a new addition to all 89+ models.
Old Dec 11, 2003 | 07:38 PM
  #18
Rice Killer87's Avatar
im not sure what '88 cars u have been lookin at,but 87 was the last year for the 9th injector as far as i knew...and i thought i knew a decent amount.
Old Dec 11, 2003 | 08:04 PM
  #19
92_RS_305's Avatar
Ok, I just got some new info on the motor....it's a '89 305 TPI it's goin on my '92 RS 305 Depending on whether keepin it MAF is easier to do than converting to SD then that's what I'll do....I may just convert to SD if that's easier that way I can get an ECM out of a '92 Z28
Old Dec 12, 2003 | 01:44 AM
  #20
90rocz's Avatar
You already are S/D, but wiring the Injection may be tricky, and you'll need a TPI S/D ECM or Prom...
If you're getting the intake w/harness, I'd go MAF...
What all are you getting??
Old Dec 12, 2003 | 09:20 AM
  #21
92_RS_305's Avatar
pretty much everything intake, intake manifold, injectors, fuel pump, fuel lines, and all that except for the wiring harness
Old Dec 12, 2003 | 12:08 PM
  #22
90rocz's Avatar
You'll have to have the *8* injector connectors with some wire on them , or an injector harness from companies like "Painless Wiring"..
You'll need a wiring diagram for both motors, library's will get you copies of the pages you need.
The wires should go like this:
The left(drivers side)bank of injectors, the "white" wire on your current injection harness, goes to the "black" wires on all 4 injectors on this bank. The "dark green" wire on your harness goes to the "black/pink stripe" wires of all 4 injectors of this bank.
The right(passenger side)bank of injectors, the "red" wire on you injector harness, goes to the "black" wires of all 4 injectors on this bank. The "dark blue" wire on your harness goes to the "black/light green stripe" wire on all 4 injectors of this bank.
That is supposing you at least got the '89's injector connectors with some wire left on them...
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
