350 tpi missing help!!
Old May 10, 2003 | 08:05 PM
19WS6T/A91's Avatar
my car is missing, it only happens when it reaches operating temp, the egr valve is good, the iac still sucks hard even when missing, cap and rotor are good, plugs cant have more than 2k miles on them, wires cant have more than 7k or so. i think that is all i check so far.
Old May 10, 2003 | 08:44 PM
Brett H. - 89GTA's Avatar
I wouldn't assume that things are OK just because they have been replaced recently. A couple of years ago my GTA developed a bad miss only 3 months after I put a set of MSD plug wires on it. Turns out that one of the wires got a small hole burnt in it. I'd still start out with verifying the basics and go from there. If the car is only misfiring in closed loop I'd also hook up a scan tool and see what else turns up.
Old May 11, 2003 | 02:34 AM
aklim's Avatar
Take out the plugs and see if any of them is different from the rest. It could be that when one of your wires heats up, it acts up or one of your plugs is bad.
Old May 11, 2003 | 05:19 PM
19WS6T/A91's Avatar
i just checked the injectors they were all between 17.2 and 17.6 ohms, i dont know what to try next.
Old May 11, 2003 | 06:27 PM
jp2002ls1's Avatar
Check your coil, check the ohms.
Old May 11, 2003 | 06:46 PM
19WS6T/A91's Avatar
how do i go about doing that? what should it read?
thank you
david
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
94Form
Jul 17, 2015 10:56 PM
asilomar244
Jul 12, 2015 05:53 AM
ducttape1975
Jul 10, 2015 06:29 PM
