305 TPI 5 speed
Old Nov 2, 2005 | 10:23 PM
  #31
IrocManiac's Avatar
Re: 305 TPI 5 speed
Originally Posted by LT193
Thats really amazing, i wonder if that manifold passes smog though. Hey does anyone know if 350 heads bolt up to a 305? Or do they have a different set of heads all together?
They have different heads, the bolt pattern changed on two bolts in 87 or 88 I think. But if you've got LB9 heads from 90 and L98 heads from 90 they're interchangeable with obvious affects on performance.
Old Nov 4, 2005 | 12:00 AM
  #32
LT193's Avatar
Re: 305 TPI 5 speed
so 350 chevy heads wont bolt up to a 305 at all?
Old Nov 4, 2005 | 01:28 AM
  #33
Nate86's Avatar
Re: 305 TPI 5 speed
Yes, 350 heads and 305 heads are interchangable on either engine. However, a 350 head on a 305 will cause a servere drop in compression, which in turn may cause a loss of power.
The 305 heads had 58cc combustion chambers, the 350 heads had (I believe) 64cc chambers.
Old Nov 4, 2005 | 07:55 AM
  #34
IrocManiac's Avatar
Re: 305 TPI 5 speed
Generally you dont see a drop in power but the gain is nowhere near what people expect because of the very reason you listed. Switching to a different gasket can help bump that compression up just a little more.
Old Nov 6, 2005 | 01:04 AM
  #35
LT193's Avatar
Re: 305 TPI 5 speed
K so if i wanted to put some 350 vortech heads on my 305 TPI i could do this? OR i would have to use normal 350 heads? Also, why is it that the motor just doesnt have as much horspower as a 350? The 3.74 bore im assuming.
Old Nov 6, 2005 | 07:10 AM
  #36
91-Z28-L98's Avatar
Re: 305 TPI 5 speed
Wouldn't putting 350 heads on a 305 compound the 305's valve shrouding problem since the valves on the 350 are bigger?
Old Nov 6, 2005 | 07:26 AM
  #37
Dave89IROC's Avatar
Re: 305 TPI 5 speed
definately, that is a issue
Old Nov 8, 2005 | 03:15 PM
  #38
LT193's Avatar
Re: 305 TPI 5 speed
Yeah but the bore is still just really small. We are working on saving for an SLP Exaust for my buddies setup right now. Ill let u know his mods, how it goes, money spent, and what he runs. He wants alot of power but still pass smog so ive turned him onto a vortech supercharger. Which makes 325 hp on a 305 bone stock.
Old Nov 9, 2005 | 01:25 AM
  #39
swisscheese's Avatar
Re: 305 TPI 5 speed
I had one for two years, actually its laying in the garage and I'm thinking of putting it back on.
I was able to hang with a mostly stock ls1 (gears and exhaust)
...until i had to shift (damn i'm just too slow shifting)
Old Nov 9, 2005 | 05:43 PM
  #40
LT193's Avatar
Re: 305 TPI 5 speed
Damn thats insane, well my buddy wants his to be that fast and even more, i hope it turns out well.
Old Nov 10, 2005 | 01:07 AM
  #41
Re: 305 TPI 5 speed
Make sure you get a SQ, those are the quieter ones. Mines just too loud
Old Nov 10, 2005 | 04:02 PM
  #42
LT193's Avatar
Re: 305 TPI 5 speed
indeed :]
F'n1996Z28SS
Aug 23, 2023 11:19 PM
STR FTR 1
Feb 10, 2015 10:36 PM
hotrod 5210
Dec 22, 2014 07:28 AM
AutoRoc
Aug 7, 2002 11:45 PM
Carguy00
Aug 6, 2002 10:25 PM
