305 TPI 5 speed
Re: 305 TPI 5 speed
Originally Posted by LT193
K so give me a full intake, exaust, and heads for this car that u think would benifit shifting at 5500 rpm. I know he can shift at 5500 rpm, the super ram will go to at leaste that i know for sure, suposodly the edelbrock one aswell. Let me know, thanks.
Re: 305 TPI 5 speed
so you dont think ill lose any low end with the stealth ram? I dont think you will lose any track time shifting a TPI car at 5500 rpm or even 6000 if u got a super ram and a nice cam in there, even a cam that pulls to 5600 rpm, im sure you could shift at 5500 and be ok. So as long as the stealth ram doesnt lose any low end then i will probably have him get one. Might go a bit bigger on the cam, but still small enough to pass smog.
Re: 305 TPI 5 speed
Re: 305 TPI 5 speed
Originally Posted by IrocManiac
You will definately lose some low end in exchange for high end power. There's not really anyway around it. You could swap cams and get one for more low end grunt, but then you sacrifice some on the high end. A company called FIRST makes a pretty good intermediate intake for flowing more than a TPI setup up top but preserving some torque.
Re: 305 TPI 5 speed
Originally Posted by 85_305
From my knowledge he would actually have around the same in the low end, while also gaining a lot in the top-end. Reason being the HSR is supposed to have the same amazing power-band as an LS1, but I suppose I may be wrong
heres a quick comparison from a thread i read
RPM ---- ASM --- FIRST --- MR
2500 ---- 183 ----- 175 ----- 175
2750 ---- 215 ----- 200 ----- 200
3000 ---- 242 ----- 235 ----- 220
3250 ---- 268 ----- 265 ----- 240
3500 ---- 300 ----- 295 ----- 268
3750 ---- 318 ----- 328 ----- 283
4000 ---- 332 ----- 350 ----- 300
4250 ---- 350 ----- 367 ----- 325
4500 ---- 358 ----- 375 ----- 348
4750 ---- 360 ----- 382 ----- 363
5000 ---- 358 ----- 387 ----- 377
5250 ---- 350 ----- 374 ----- 387
5500 ---- 328 ----- 362 ----- 397
MR = Miniram
First is a different manufacturer all together that appears to have about the best combo for a daily driver/street machine. As you can see the minniram lags below about 4500 rpm. IF you're running a 1.8th mile track your times will probably slower. If you're running a 1/4 mile track going to a stealthram will probably improve your ET by a tenth or two but you'll be significantly faster from a roll.
There are differences between the stealth ram and miniram
specific stealthram flow numbers can be found here
http://www.stealthram.com/flowcomparison.html
Re: 305 TPI 5 speed
Nice chart
Looks like the miniram pulls like a **** up top; to bad your chart only goes to 5500 though
Re: 305 TPI 5 speed
what are all of those again, wow thats insane differences man omg.
I did some research last night and it looked like the fall off on a modded TPI system from 5500 to 6000 is about 54 hp. Which means on a stock TPI system it would have been closer to 75hp. Also that test was done on a SMALLER cu in motor which means the difference would have been greater on a higher discplacement motor.
Re: 305 TPI 5 speed
Originally Posted by swisscheese
I'm wondering what the differences in torque are. Im looking to upgrade my engine parts also, but i'm kinda frightened to loose too much low end.
RPM TPITQ HSRTQ TPIHP HSRHP
2,600 346 305 171 151
3,000 390 341 223 195
3,400 419 365 271 236
3,800 427 382 309 276
4,200 421 394 337 315
4,600 413 413 362 361
5,000 390 412 372 392
5,400 368 398 378 410
5,800 330 376 364 416
6,200 283 351 334 414
These were on a 355 cu in chevy
The TPI system was SLP large runners and a ported and polished plenum, runners and lower intake.
Re: 305 TPI 5 speed
Definately no Honduh-Style-engine. Usually I enjoy the torque down low. (Perhaps I should swap a diesel engine in there...
When i want to move a bit faster I shift at ~4500 rounds
)When i want to move a bit faster I shift at ~4500 rounds
Re: 305 TPI 5 speed
Whats the first intake, and where can i get one? Also, any numbers on the stealth ram? wow this is amazing to see how bad the TPI really is lol.
www.firstinjections.com
Re: 305 TPI 5 speed
Thats really amazing, i wonder if that manifold passes smog though. Hey does anyone know if 350 heads bolt up to a 305? Or do they have a different set of heads all together?
