305 to 350 swap.. what do I need?
Old Jan 4, 2004 | 11:57 PM
  #16
jcurrieirocz's Avatar
back to the orig. question yah butch or hijackers hahaha.....
dont forget you need the larger throtle body from the 350 if you werent planing on swaping to the full engine intake included like.
Also i heard you can use LS1 injectors?? i forget if there are mods to do with this swap tho.
Old Jan 5, 2004 | 12:08 AM
  #17
Zepher's Avatar
throttle bodies are the same on the 350 and 305.
LS1 injectors run at higher psi, so thier rating is lower on a 3rd gen. Example 26# LS1 injectors are 22# on our cars, 28# LS1 injectors are 24# on ours. You'll have to notch them as well so that the clips will hold them to the fuel rail.
Old Jan 5, 2004 | 12:22 AM
  #18
Oh yah really?? I thought i read or seen someplace that they were like 2mm larger or something on the 350??
Old Jan 5, 2004 | 12:23 AM
  #19
BOZS89IROC's Avatar
Just remember that the TPI was originally made to complement the 305. Thus the reason the 305 with dual catalystmade 230 h.p. and the 350 TPI only made 15 horses more. That's why L98's respond so well to oversized runners and ported manifolds. Also adding bigger injectors than requied can lead to more problems, i.e. calibration and ECM problems. Adding bigger injectors means that the ECM has to limit the injectors pulse width (time in milliseconds the injector is open). This can actually kill performance and hinder fuel efficency, which kinda defeats the purpose of F/I. The bigger injectors will have to fire so briefly that the fuel won't have time to fully and evenly mix with the air. TPIS has documented using 305 injectors for performance engines over 400 cubes with no problems. The ECM automatically adjusts the injectors pulse width and duty cycle to stoichiometric air/fuel ratio.
Old Jan 5, 2004 | 12:25 AM
  #20
Zepher's Avatar
Yep, it's a fact. They used the same 48mm TB on the 305 and 350's as well as the LT1's (with the LT1's being slightly different due to the sensors)
Old Jan 5, 2004 | 12:31 AM
  #21
ok i must be seeing 50 and 52mm aftermarkets or something on a 350 ...i forget where i seen it and stuff so i cant really back up my 1st statement guess i shouldnt of said it.
Old Jan 5, 2004 | 10:32 PM
  #22
LS198Z's Avatar
Injectors Here
Old Jan 6, 2004 | 02:04 AM
  #23
Dave89IROC's Avatar
Re: 9" I hope you ain't talkin Ford 9" i've breaken 2 of them.......
Originally posted by 91 GTA Ramair2
The 10Bolt 7.5" rear end will hold up well but only for so long then it will go.......
I'm swapping a 9" moser under my 91GTA hopfully before the 406TBI get's stuffed into it.......
But if i get into a hurry who know's what might happen...
if the 406 goes in before the Rear end swapp i'll just drive it easy as the first 4,000miles will be break in anyway.....
witch might give me enough time to save up for a.........
Dana/AMC20 rear end....... there unbeatable........
The only GM 10Bolt i can't break is the 12" 10 Bolter's.......
but then agian we ain't talkin 50's &60's GM 1 ton's.... .
Zepher BTW there is 12 Bolt's required to do the swap........
2 control arm, 2 torque arm 2 shock 2 Traction bar,4 U-Joit.
(might be 4 sway bar bolts so 16 but who's counting)
1 panhard rod
Old Jan 6, 2004 | 07:14 AM
  #24
91 GTA Ramair2's Avatar
Oh yeah I forgot that too.........
I guess Now I am
HAWG
Sep 25, 2015 11:41 AM
Tarizza
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
