"Performance mode" on 2010 SS M6
from what i see you press the button once it takes traction control off but stable track is on,stable track will apply brake pressure to witch ever tire needs it so the car goes straight, it feels pretty crazy, to totally take off all traction you will have to push hold for 10sec, their will be 2 icons in the dash @ this time one will look like a burnout and the other has a tc with circle around it,then you will have no traction control or stable trrck on @ this time and it rips the tires off lol.competive mode you push 2x fast and then you will have the burnout icon, it will not burnout very good that way if @ all.
But I'm still a rookie and need lessons, please.
Bob
I have to assume that any good tuner can make the system default to off. For your daily driver that would not be wise, but if you just race your car I can see justification. These pereli tires are just too darn expensive for me to remember to turn the TC on. The tires on this thing are so good you almost don't need TC unless you are power-stalling or its really cold outside. I'm pushing WELL over 400HP with the mods I have done and I have to stand on the brake to get them to light up, that is with everything turned off.
If you guys couldn't tell or didn't know, Bob is a very seasoned drag racer
I wonder if a tuner can change the RPM that the Performance Mode limits the RPM?
I wonder if this program could be implemented to work with an auto that has a loose converter?
Heh, you win at the internetz.
Im not sure why all the sarcasm is about. Since he is a seasoned drag racer I guess he doesnt need to learn to drive. A seasoned drag racer probably doesnt care to much about a launch control anyway. I dont know if you guys are actually getting your panties in a wad or what lol. He got his answer from his question, seeing as a doubt GM is going to allow a setting for slicks on their launch control.
I should have clarified it should be over 400 at the crank, I'm guessing 440-450 with the tune and exhaust. I guess that does not matter since most people
are concerned with what is at the wheels. The car is going to the dyno in a couple weeks and I will post the results then.
Does this void your warranty?
A co-worker of mine just got his 2SS and read about the launch option in the manual. It says to refer to the warranty paperwork somewhere in there. In the warranty paperwork it said using the launch option voids your warranty. Now, I did not read this myself. This is second hand info and I'm curious what you all have seen on it.
mschmidt33
Mar 15, 2015 07:20 PM
Dec 4, 2014 11:56 AM
