"Performance mode" on 2010 SS M6
Old Jul 31, 2009 | 10:08 AM
  #16
JakeRobb's Avatar
Super Moderator
Originally Posted by absolute1ss
stable track
It's called StabiliTrac.
Old Jul 31, 2009 | 10:57 AM
  #17
Bob Cosby's Avatar
from what i see you press the button once it takes traction control off but stable track is on,stable track will apply brake pressure to witch ever tire needs it so the car goes straight, it feels pretty crazy, to totally take off all traction you will have to push hold for 10sec, their will be 2 icons in the dash @ this time one will look like a burnout and the other has a tc with circle around it,then you will have no traction control or stable trrck on @ this time and it rips the tires off lol.competive mode you push 2x fast and then you will have the burnout icon, it will not burnout very good that way if @ all.
Interesting. Once the computer tuners get a good handle on these cars, I wonder if they'll be able to disable it completely? When I first started competitively racing my 99 Cobra, I would occasionally forget to turn off the Traction Control (one push of a button on the center console). This would absolutely RUIN a burnout (duh), and mess up my routine and the run. After this happened a couple of times, I made myself a sign that I put in front of the button that said "Turn off TC!" so that it wouldn't happen again, and eventually had the computer changed so that the TC defaulted to off.
But I'm still a rookie and need lessons, please.
Bob
Old Aug 1, 2009 | 01:42 AM
  #18
wacker's Avatar
I have to assume that any good tuner can make the system default to off. For your daily driver that would not be wise, but if you just race your car I can see justification. These pereli tires are just too darn expensive for me to remember to turn the TC on. The tires on this thing are so good you almost don't need TC unless you are power-stalling or its really cold outside. I'm pushing WELL over 400HP with the mods I have done and I have to stand on the brake to get them to light up, that is with everything turned off.
Old Aug 1, 2009 | 04:08 AM
  #19
AdioSS's Avatar
West South Central Moderator
If you guys couldn't tell or didn't know, Bob is a very seasoned drag racer
I wonder if a tuner can change the RPM that the Performance Mode limits the RPM?
I wonder if this program could be implemented to work with an auto that has a loose converter?
Old Aug 1, 2009 | 12:32 PM
  #20
bossco's Avatar
Originally Posted by supernova1972
Learn to drive.
Heh, you win at the internetz.
Old Aug 1, 2009 | 02:04 PM
  #21
JasonD's Avatar
Admin Emeritus
Originally Posted by bossco
LOL, that's okay...Bob is modest.
Old Aug 1, 2009 | 03:35 PM
  #22
supernova1972's Avatar
Im not sure why all the sarcasm is about. Since he is a seasoned drag racer I guess he doesnt need to learn to drive. A seasoned drag racer probably doesnt care to much about a launch control anyway. I dont know if you guys are actually getting your panties in a wad or what lol. He got his answer from his question, seeing as a doubt GM is going to allow a setting for slicks on their launch control.
Old Aug 1, 2009 | 03:52 PM
  #23
JakeRobb's Avatar
Super Moderator
Stock, a 2010 Camaro puts down ~360hp to the wheels. You have a catback and a tune and you think that gets you well over 40 additional horsepower?
Old Aug 6, 2009 | 12:17 AM
  #24
wacker's Avatar
I should have clarified it should be over 400 at the crank, I'm guessing 440-450 with the tune and exhaust. I guess that does not matter since most people are concerned with what is at the wheels. The car is going to the dyno in a couple weeks and I will post the results then.
Old Aug 9, 2009 | 09:57 PM
  #25
That Camaro Guy's Avatar
Does this void your warranty?
A co-worker of mine just got his 2SS and read about the launch option in the manual. It says to refer to the warranty paperwork somewhere in there. In the warranty paperwork it said using the launch option voids your warranty. Now, I did not read this myself. This is second hand info and I'm curious what you all have seen on it.
blkWidow
Apr 20, 2015 09:27 AM
mschmidt33
Mar 15, 2015 07:20 PM
redleader
Jan 22, 2015 12:05 PM
Dec 4, 2014 11:56 AM
