My Tranny shifts like a girl
Old Aug 19, 2009 | 06:10 AM
  #31
JasonD's Avatar
Admin Emeritus
Originally Posted by wacker
Are you able to scratch the tires yet during shifts?
Yep, barks second rather decent.
Old Aug 19, 2009 | 08:09 AM
  #32
wacker's Avatar
Nice. maybe a little more line pressure and some tweaking on your tune and you will see 3rd
Old Aug 19, 2009 | 09:58 AM
  #33
wacker's Avatar
Do you know the exact RPM the tranny is shifting at now, based off a log since the tac lags.
Old Aug 23, 2009 | 02:02 PM
  #34
wacker's Avatar
Are you running any TM for the up shifts? What line pressure are you running now?
Old Aug 23, 2009 | 02:08 PM
  #35
JasonD's Avatar
Admin Emeritus
I don't have this information yet, the program is still being tweaked.
Old Aug 23, 2009 | 02:17 PM
  #36
wacker's Avatar
Roger, Right now all TM for up shifts have been removed and my line pressure is set to peak at 200psi (max recommended). But depending on which table you are looking at it is limited to 94psi. When my tuner gets back from vacation we will continue tweaking the line pressure and I'll keep you posted. The max timing I'm seeing is 32 degrees as compared to 22 degrees stock. The long tubes, cats and CAI should allow for even more aggressive timing.
Old Sep 2, 2009 | 10:11 AM
  #37
DavidCZ75's Avatar
My 1SS seems to shift just fine.....
Old Mar 31, 2010 | 11:34 AM
  #38
john phillips's Avatar
Normally after the trans gets "broke in" they will useually shift about 30% firmer
Cam's maro
Aug 11, 2015 07:45 AM
wesley81
Jul 27, 2015 11:31 AM
Boss002
Jul 24, 2015 10:47 AM
browenb
Jul 19, 2015 04:14 PM
