Big Block Camaro
Dumb idea.
1. Big blocks are very heavy.
2. Small blocks put out phenominal horsepower nowadays.
3. GM created a 427 out of a small block.
4. Fuel economy of a big block downright blows.
The most powerful 454 (the LS6) put out 450 horsepower and 500 lbs/ft of torque by the optimistic, old, "gross" horsepower measurement.
That motor had solid lifter from the factory as well as a 850 cfm carb...It was rated that low solely b/c insurance companies were starting to crack down and they went by HP ratings on cars like that. My BBC that was on my 79 Z had HYDRAULIC lifters,LESS CAM, and the same size carb and had around 500HP easy to push that sled to 11.0X in the 1/4 everytime down the track.
LMAO. Find me a SBC car w/ a flat tappet cam,runs on 93,has FACTORY heads that runs 11 flat/7.0's in the 1/8 in a 3400 car. YOU WONT !!
And dont go find some LSX motor w/ some huge camshaft and milled heads call it stock.
By the way, if you want to go fast for cheap than SBC + supercharger or N2O will beat your BBC any day in the HP per $ competition.
I still think a big inch LSX would be the best choice, we all know that GM has the capability to do that.
There is a range (somewhere between 500-700hp) that a BBC has the advantage. You don't need forced induction and factory parts with after market heads can make the power you need. Above and below that though, you can't beat an SBC.
ChrisFrez
Nov 30, 2014 08:41 AM
Skull Leader
Aug 10, 2002 11:01 AM
What kind of fuel mileage does that BBC get?
